Page 1 of 2
dirt cheap touring wagon parts
Posted: Thu Aug 11, 2011 6:46 pm
by mud_king91
im parting out the touring wagon so if theres anything you need pm me or call me on 0428984838
Posted: Thu Aug 11, 2011 6:47 pm
by Dann
how much do you recon it would be to get the fuel tank over to wa perth ??
Posted: Thu Aug 11, 2011 6:49 pm
by mud_king91
not sure its 100 for the fuel system (tank to injectors) so ill pull it out tomorrow and get you an approx size and weight
Posted: Thu Aug 11, 2011 6:57 pm
by Dann
if that's ok, i'm just hoping that the postage isn't to high
Posted: Thu Aug 11, 2011 6:59 pm
by mud_king91
it shouldnt be the only thing that would boost it up is its a fuel tank but yea ill find out
Posted: Thu Aug 11, 2011 8:00 pm
by shuffbag
if it has 25 spline front drive shafts i would be keen, it is efi? and maybe struts all round if they are the ones with slight adjustment?
Posted: Thu Aug 11, 2011 8:16 pm
by mud_king91
shuffbag wrote:if it has 25 spline front drive shafts i would be keen, it is efi? and maybe struts all round if they are the ones with slight adjustment?
im stripping her tomorrow so ill count splines and i dont think its adjustable (first thing i searched for) but on the plus side im selling everything dirt cheap (160 for all for C.V,s and full suspension system)
Posted: Thu Aug 11, 2011 10:17 pm
by guyph_01
Hi,
I'm after the cargo blind catch is the little plastic bracket that stops the rear cargo blind from going back.
The cargo blind is that trap thing that covers the back bit of the cargo/tray area.
Colour doesn't matter.
As the one above the blue switch.( pic is LH) I want the RH:)
Thx
Is this the grey one that your are wreaking? I also need some other grey trim bits.
- The center bolt cover trim bit for the dash. It sits in the middle of the dash just under the windscreen and covers the bolt that bolts the dash to the car.
- Also after the grey trim on the left of the steering wheel just under the taco. Next to the rear wiper switch i think.
- Also after the trim that covers the top part of the rear seat belt mounting bolt on the body.
I'll pm you the pics of the parts and maybe some more parts:)
Posted: Thu Aug 11, 2011 10:27 pm
by mud_king91
Yea its the grey one and i dont have the cargo catch thingy
Posted: Thu Aug 11, 2011 11:39 pm
by apg39
Have you got power steering for sale? Very keen if you do.
Posted: Fri Aug 12, 2011 12:35 am
by tony
you are looking for trouble posting or sending a fuel tank. it is a highly explosive item as it is very difficult to neutralise the petrol fumes. if it does go up during transport it could get both of you in to very serious trouble. ask niterider.
there must be a fuel tank in perth, i assume you are looking for a efi one?
Posted: Fri Aug 12, 2011 12:39 am
by tony
guyph i probably have most of the internal bits you want, i did throw a lot of them out on wednesday i did not realise you wanted them. i do have the seatbelt thing, the centre bolt cover, and maybe the dash trim.
will check but will take a week or so. do not have the cargo clip don't have them on any of my l series.
Posted: Fri Aug 12, 2011 6:20 am
by Gannon
If it has power steering, can I have the knuckle that joins the shaft to the rack?
Looks like this
Posted: Fri Aug 12, 2011 6:26 am
by mud_king91
Yes it has power steeering the rack looks like its starting to wear tho
gas struts on cargo door
Posted: Fri Aug 12, 2011 10:06 am
by Fatman69
Are the Gas struts on the cargo door any good if so im interested , mine are gone
Posted: Fri Aug 12, 2011 10:27 am
by mud_king91
They were the first to officially go
Posted: Fri Aug 12, 2011 12:37 pm
by Dann
yeah I see what you mean about the fuel tank tony :S ... mmmm
yeah mabey not then mud_king91.
Finding it abit hard to get one with the lines in Perth at the moment though.
Posted: Fri Aug 12, 2011 4:35 pm
by Gannon
Not worried about the rack, just want the shaft with the uni joints on it
mud_king91 wrote:Yes it has power steeering the rack looks like its starting to wear tho
Posted: Fri Aug 12, 2011 6:56 pm
by mud_king91
Gannon wrote:Not worried about the rack, just want the shaft with the uni joints on it
ill pull that out tomorrow when i start cutting her
Dann wrote:yeah I see what you mean about the fuel tank tony :S ... mmmm
ill keep it aside as my father in law owns a few businessess in and around perth so he may be able to organise something... ill ask him this week end
Posted: Sat Aug 13, 2011 6:59 pm
by mud_king91
Gannon wrote:If it has power steering, can I have the knuckle that joins the shaft to the rack?
Looks like this
My knuckle looks nothing like that
