Sell 1990 L Series Sportswagon
alx92
Post by alx92 » Wed Aug 08, 2012 10:50 am
G'day all,
Unfortunately im selling my wagon, "Scooby"
The Good:
1.8L EA82 engine 332XXXkm’s;
Weber 32/36 DGV 5A (manual choke) carburettor conversion, K&N filter;
Brand new 2.25” Sports exhaust;
5spd Manual with Hi & Low range 4x4 on the fly;
2” Body Lift (3” rear shock brackets);
4x 14” Sunraysia wheels with 27x8.5” BFGoodrich AT tyres (DONT MAKE THESE TYRES ANYMORE), 1x Peugeot 504 14” rim as spare;
converted to power steering;
Oricom 80ch mini-din UHF; aftermarket head unit with Aux/USB/SD card input, 4x6” speakers;
Towbar with Flat & Large 7 pin connectors;
full replacement alloy bulbar with Night Vision Spotlights;
Rola Roof racks (Standard);
SAAS Steering wheel;
Just had new front brake discs & pads and rear shoes and cylinders fitted by Sunspares Yandina.
NO RUST IN WINDSCREEN SURROUND all original steel, not rust anywhere else other than the odd little surface scratch
The Bad:
Vacuum Leak somewhere (Suspect dodgey gasket in the carburettor, easy fix) so theres a bit of a flat spot when running without full choke, just gotta rev it a bit more to take off
Small hole starting in (i think) the RHF CV boot
Selling as is, NO RWC, will leave the rego so you can drive it home etc.
Should only require (possibly) the CV boot and vacuum leak sorted, as well as fitting standard size 170x70R13 wheels and tyres (will supply)
Selling due to personal reasons, regretful sale.
Please ask any questions you may have
Looking around $3000 ono
Deposit required within 24h of sale, final arrangements will be settled afterwards
