Supercharger system for EA81
Tweety
Post by Tweety » Mon Aug 12, 2013 3:41 pm
Well known to regular readers I have the near complete system for sale set up for draw through at 5 psi. The system includes:
- Toyota SC12 supercharger in fair to good working order. The lobes have a few light scores but is working well. Has new oil and doesnt use oil. Pulley on SC is standard size bolted solid. System uses 5 ribbed belt system and is lined up correctly
- Custom modified Datsun (Lynx) manifold carbie to sC. Has plug for water injection and brass fitting for vacuum points.
- Custom manifold SC to stock manifold. Has good quality blow off valve for backfire insurance. Bolts onto your stock manifold.
- 40DHLA Dellorto carbie. Been dyno tuned. Spare carbie for parts. Spare jets.
- Crank pulley that includes 5 ribbed pulley plus water pump/alt pulley (have got it off the engine yet)
- Complete water injection system. Snow performance pump at 220 psi, tank, filter, switch that turns on when boost begins (plumbs to manifold) and injector that can easily bolt to intake manifold.
- Recalibrated dizzy requires no vacuum. Advances 18 degrees. Dizzy shaft in VGC and recoed by an ignition specialist.
- All mounts included.
- buyer needs to supply boost gauge of their choosing and air filter. Buyer can raise the pressure by fitting a smaller SC pulley. Buyer to pay for freight ex Shepparton Victoria.
$1300 plus freight
Tony
Tweety
Post by Tweety » Sat Aug 24, 2013 8:54 pm
Didnt sell first auction. relisted at $600+. wont go lower.
