90 Subaru L Series Sportswagon [Brisbane]
Posted: Tue Jan 07, 2014 11:12 am
by dkw
Bought this about 2 years ago. Spent a fair bit of time ad money to fix it up and get it up to roadworthy standard. Ever since then it's been a very reliable and dependable car.
Body and paint are in pretty good straight condition for age with minimal rust that I can see though the decals have peeled somewhat.
Interior: The seats and mats are in pretty good condition though the top of the door padding has been affected by the sun quite badly. Very large cargo area (has certainly come in handy). Has an Alpine stereo but the head unit has stopped working. If you can fix this or replace the head unit you will have a decent little system because Alpine make great car speakers. Left door lock is missing or more accurately somewhere in the door cavity. Aircon works reasonably well but isn't freezing.
Engine is very strong and is quite enjoyable to row along actually and has been well maintained in my ownership. Have serviced it every 5,000km's although it is currently 7 or 8,000km's since the last service. About once or twice a month it will develop lifter noise which disappears after a day or 2. This is very common with these engines and does not harm the engine in any way. It also has an oil leak (not serious) which is another thing very common with these engines - try and fine one without a leak haha. Recently it has become temperamental on startup and you have to have it well and truly warmed up or it will splutter. I'm guessing either the carburetor needs a good clean (Subaru's Upper Engine Cleaner might do the trick) or possibly needs a new fuel filter. But again the engine is very strong and should last another 100,000km's with proper maintenance.
The gearbox is very sloppy and just needs some bushes (cheap) to locate the gearstick properly which is an easy fix. 3rd gear can be notchy (wearing synchro perhaps?) but as long as you don't rush it it's absolutely fine and hasn't gotten worse in my ownership.
Under braking there is some shudder through the brake pedal and steering which I believe is due to slight warped front discs. It's not at a dangerous level though may need to be replaced for a roadworthy.
Tires and suspension are good. Has upgraded 14" wheels.
What has been fixed or replaced:
- Sports exhaust with sports cat (sounds great)
- K&N Sports Air Filter
- Right and left hand rocker cover gaskets
- Front strut mounts
- Rust in the rear wheel wells
- Battery
- Front CV drive shaft
- Front discs
- Engine and accessories belt plus relevant seals and gaskets for that job
- Tires
- I think there were a few other suspension pieces replaced
Has rego until March but you will need to get your own roadworthy. I'd fix the niggling problems up myself but simply don't have the time.
Looking for a very quick sale as am going overseas. Located in Toowong, Brisbane.
$1250 ono. Call or text Damien on 0433 637 189.
