QLD Complete Brumby air/con set up
Posted: Fri Jan 17, 2014 9:43 pm
by Proton mouse
Hey all,
I have just removed for sale a complete air conditioning set up to suit any 'MY' or EA81 type car i.e. Brumby to '92 or wagons, sedans and coupes to end of 84.
It was a working system, still had gas in it with dye, and had no leaks, and the systems parts were all sealed with tape upon opening.
You will get...
Compressor with its steel girder type bracket, lol + all attaching bolts and little spacer.
Condenser and accumulator with all alloy pipe work and bracket/bolts.
Evaporator in its housing (the evap face does need a clean)
All associated wiring/relays/push button a/c switch which are all tagged with written instruction for easy assembly. Plus can email 'before' pics to help also.
Belt and pulley (pulley if required)
Extra thermo fan (if you need it)
'Idle up' solenoid, bracket and vac lines.
The only thing missing was the glovebox insert with the corner cut out for the evap housing.
Located on the Sth side of Brisbane, inspection is welcome.
Buy with confidence as I have spare compressors and other parts so I can guarantee to get you cooled!!
Call or text till late (read that as not early!! lol) or reply via here.
I am not always on here so ph/txt is quickest.
John 0404 186 738
$450 the lot.
Can ship Australia wide at buyers expense.
(last complete kit I sent to Adelaide was $75 via e-go couriers, just to give you an idea)
