L series full RX turbo conversion
Posted: Fri Oct 10, 2014 9:22 pm
It's come time to sell the subi cos I need a 'family car'
The car is a 1985 GL wagon with a full RX conversion including:
1986 3 pin ecu flapper turbo engine,
4 wheel disk brakes,
LSD,
RX dash,
RX front seats.
Conversion was done by Subawreck I believe
Also has:
2.5" (I think) exhaust turbo back
14" sunraysia wheels with 70-80% tyres (100% on the spare),
Roof racks with bolts for long handle shovel,
Aluminium roo bar,
2 100w spotties,
New plugs 1000km ago,
New plugs leads 5000km ago
New dizzy cap yesterday,
New oil tomorrow,
LED white interior lights,
New coolant temp sensor 500km ago,
New radiator and coolant yesterday,
New fuel and oil filters 5000km ago,
New diff oil 10000km ago,
2" lift kit,
Tow bar,
Extended wheel arch rubber,
New front discs 10000km ago
New thermostat and radiator cap 1000km ago.
Odometer reads 260,000 ish.
I've done about 20,000km in it in the last 2 years and done almost all the servicing every 5000km
Body is straight, bit of rust around the windscreen
Paint isn't in the best nick but not bad. It's white
Has air conditioning which works but needs a top up
All the electrics work fine
Bit of an oil leak from the head seals I think but not enough to require topping up between oil changes.
Sway bar bushes and gear shifter bushes are a little worn
Have gone 4x4ing a couple of times and the 4h and 4l and lsd works perfectly.
Car is located in Adelaide
Can be seen most weeknights and weekends
Call/sms Andrew 0438 849 614 or PM
Price is $2,700 neg
Photos to come
LSD,
RX dash,
RX front seats.
Also has:
Aluminium roo bar,
2 100w spotties,
New oil tomorrow,
2" lift kit,
Tow bar,
Price is $2,700 neg
Photos to come
