WTB: timing covers / No.2 cam sprocket / Cam sensor
Posted: Sun Mar 17, 2013 12:57 pm
by dyrgutt
[Suit a 2.5L, but I Imagine these parts would be common to most?]
Hey guys, i'm after a camshaft sprocket/pulley/wheel/whatever [no.2 - the one that has the camshaft position sensor behind it]. Mine is kaput! I'm also after the position sensor as well, and the plastic timing covers. Does anyone have a wreck / buggered motor they wouldn't mind ratting for a few bucks [or swapping]? Cheers guys.
Posted: Sun Mar 17, 2013 3:25 pm
by RSR 555
I will have the LH Camshaft Pulley but will not be home for 2.5 weeks. As for the Camshaft sensor and covers, I would have them too but would recommend you contact Frog (Andy) as they aren't too expensive new and would highly recommend you use a new sensor everytime.
Posted: Mon Mar 18, 2013 6:45 am
by dyrgutt
...Normally I couldnt agree more RSR 555, but I just want to make sure this little labour of love runs before throwing anymore time/energy at it. Though, I might hold off getting the covers until I make sure she turns over and runs, in which case - i'll hit-up andy for some decent goodies. As she's really a project, i'm not fussed about the 2.5 weeks mate, so let us know what you're chasing/after for the sprocket and sensor? Thanks Peter
Posted: Mon Mar 18, 2013 10:29 am
by RSR 555
No worries Peter, you may need to remind me as time gets closer.
Normally I'd let people in WA take the sensor and try it out, then if it works, I ask them to bring mine back and buy themselves a new one but seeing as you're over East, this will be hard.
Can you tell us why you suspect your one is a problem?
Posted: Tue Mar 19, 2013 9:10 pm
by dyrgutt
Sorry for the tardy reply RSR, I've been flat out...yeah, my sensor took some impact along with the sprocket - but more damage was inflicted than I first thought. I was in the process of removing the sensor when I noticed the alloy bracket that holds it appeared a little skew; so upon wiggling it, she snapped off!!! *grrr*. Better to find out now I suppose. Anyhow, you wouldn't want to get rid of that bracket as well would you? - haha. Thanks mate.
Posted: Wed Mar 20, 2013 11:00 am
by RSR 555
Damn.. how you off for jocks and socks?? hahaha.. only kidding
I'll have a look when I get home, I'm sure there's 1 or 2 lying around.
Posted: Wed Mar 20, 2013 6:58 pm
by dyrgutt
haha...Thanks mate, i'll hit you up in a couple of weeks to remind you; by then, I might even pester you for some unicorn ear wax if you have any spare ;)
Posted: Wed Apr 17, 2013 7:46 pm
by dyrgutt
Still looking guys, if you know of anything - let us know ;) Cheers
Posted: Wed Apr 17, 2013 11:17 pm
by RSR 555
I still have but need 48hrs in a day.. sorry
Posted: Fri Apr 19, 2013 10:11 am
by dyrgutt
haha, don't we all - but then I(we) would just double the amount our of projects? Let us know when you can mate, cheers Peter
Posted: Wed May 01, 2013 8:48 am
by dyrgutt
Hey Paul, any luck mate?
Posted: Wed May 01, 2013 5:39 pm
by FROG
PM me your vin and I''ll price it all up
regards Andy
Im away next week explorin' so :) if you can get it to me before Friday
Posted: Thu May 09, 2013 9:04 am
by dyrgutt
Hey Frog, thanks for the offer mate - but I imagine all that gear would probably be more than what the motor is worth brand new [...as I'm not sure it's even going to run]. I have a fair bit of Forester MY00 gear that I could swap with someone if they're keen? Thanks guys.
Posted: Fri May 10, 2013 12:49 am
by RSR 555
dyrgutt wrote:Hey Paul, any luck mate?
Yep. I found the engine and will be able to get the bits off it this weekend. I did notice the Camshaft sensor was missing, so I guess it was used on something else. I've been fighting for room since building the office/engine room but now that it's done, I'll be able to move some stuff around. Sorry for the delay
Posted: Fri May 10, 2013 11:44 am
by dyrgutt
Awesome mate, bugger about the sensor being removed...hopefully the small alloy bracket that holds the sensor is available, though? Cheers Peter
Posted: Fri May 10, 2013 5:02 pm
by RSR 555
Hey Peter, I'm 99% sure the bracket is still there. I will check and if it's there, it's yours.
Posted: Tue May 14, 2013 2:08 pm
by dyrgutt
^ did you have any success mate or are you still a bit snowed under? cheers Peter
Posted: Wed May 15, 2013 8:40 am
by RSR 555
Hey Peter, yes I finally had success. I think I have everything except the sensor? The LHR cover is broken in the usual spots (where the nuts are moulded into) but it was holding the front cover on, so you'll get away with it for now.
1x LHF timing cover
1x LHR timing cover
1x LH timing sprocket
1x Camshaft sensor bracket
I have them ready to post. Are you able to PM me your postal details?
Paul
