WTB EA81 dual belt pulleys
Posted: Wed Jul 03, 2013 9:25 am
by Venom
Edit: Actually just after a double or triple belt alternator pulley for an EA81.
PM me if you have anything.
Posted: Wed Jul 03, 2013 1:52 pm
i think the dual crank pulley is actually a triple , say you'll be happy with a triple as well;
Posted: Wed Jul 03, 2013 6:34 pm
by Silverbullet
I've got two, you can have one of mine. One came with my new engine, and another came with an incomplete p/steering lot I bought. No idea what it's worth, shoot me a PM if you're interested.
*Edit* Just re-read "alternator pulley" Do you mean the pulley that is on the alternator? I had no idea there were multi-ribbed versions. I was talking about crank pulleys.
Posted: Wed Jul 03, 2013 7:01 pm
by Venom
Silverbullet wrote:I've got two, you can have one of mine. One came with my new engine, and another came with an incomplete p/steering lot I bought. No idea what it's worth, shoot me a PM if you're interested.
I'm pretty sure the cars with A/C have a multi belt pulley for the alternator.
Posted: Wed Jul 03, 2013 7:54 pm
by TOONGA
Get an ea82 alternator from an "L" with an aircon setup.
Posted: Thu Jul 04, 2013 8:08 am
Hmm, do EA82 crank pulleys fit EA81's ?? They are bigger diameter pulley, pretty sure of that much. Just for info...I have had a few EA82 with AC.... PS pulley has two grooves, only one ever had a twin groove alternator and that was an 89 mpfi touring wagon, so n ot all AC EA82's had 'em
Posted: Thu Jul 04, 2013 9:14 am
by 555Ron
I'm pretty sure there is no such thing as a double pulley for the alternator. The EA81T has a double pulley for the water pump. The crank pulley needs upgrading to install the a/c setup. Everything else will just bolt on to the block...
Posted: Thu Jul 04, 2013 10:13 am
You may rephrase that so not to get shot down
You are referring to EA81T Rhys ?
Posted: Thu Jul 04, 2013 10:56 am
Hmmm.
I know the crank pulley is a triple pulley, but I've not known the EA81s to run a double on the alternator itself.
If your after the crank pulley I've got one you can have, especially if I can have your single pulley in exchange to keep the engine sealed up
What is it that you're up to - installing AC?
If it is an alternator pulley I should have one of them on an L series alternator somewhere...
Posted: Fri Jul 05, 2013 8:07 am
555Ron wrote:I'm pretty sure there is no such thing as a double pulley for the alternator. The EA81T has a double pulley for the water pump. The crank pulley needs upgrading to install the a/c setup. Everything else will just bolt on to the block...
Teacher working too hard ?
El_Freddo wrote:Hmmm.
Teacher working too hard?
Posted: Fri Jul 05, 2013 6:19 pm
by TOONGA
