Hi all, I am after a few things to try and finish this conversion I decided to punish myself with, tail shaft either a 2 piece with centre mounts or is it just simpler to get the standard tail shaft lengthened, carpet, exhaust from engine pipes back , and heater pipe the 'S" control valve also needed or does anyone no how to convert a commodore vacuum operated one I am on the Gold Coast but prepared to travel within reason to pick up
Thanks
Brumby Shopping List
Best to get a 2 piece made to suit the Brumby and make a centre mount bracket.
No Brumby has carpet, so best to find one from a MY Touring Wagon or find someone selling new ones.
Exhaust for what engine?
As for the heater tap. I'd look at getting a good secondhand one.
rsr55 thanks for that will be chasing 2 piece tail shaft found and after market carpet in Victoria (bet it was from L series) exhaust yes should have mentioned it is an EA81 brumby fitting 5 speed into it just need from engine pipes back. looks like I have to get one made and for heater tap I have worked out how to adapt the tap from a commodore
Thanks for your help
