Looking for a set of (5) original MY/Brumby Sunnies style white rims (and caps if possible) with 140mm PCD x 4 stud.
Need to be in good condition with no cracks or major rust.
Need to be a max of 45mm offset but less, ie, 35mm better.
L series Sunnies no good as I already have a set of these and they are 55mm offset.
The wanted rims will be 5"' wide.
Happy to pay freight but if anyone is in the Hunter Valley near Newcastle I can come and pick them up.
Let me know what is out there.
						Wanted original MY Sunnies rims
- Green_eyed_liberty
The rims sound good.
The offset is critical for what I am after.
If possible could you please measure the distance (on the inner rim side) from the outside edge of a rim to the face where the rim sits on the hub.
I know this isn't the offset dimension but I have measured both the MY alloys with an offset of 45mm and the dimension I am asking for about (in my case) is 122mm. Likewise on the 92 model L series rims their offset is 55mm and the dimension I am asking for is about 134mm.
Basically, the dimension I am asking for should be about-
MY/Brumby: 122mm
L series : 134mm
I will be looking for lesser dimension of 122mm or less.
Thanks for the reply.
MY/Brumby: 122mm
L series : 134mm
