L series flywheel and associated parts (WA)
- TOONGA
Western Australian members I need an "L" Series flywheel, throw out bearing, pressure plate, cable and pedal and friction disc. For my brumby 5 speed conversion. As I'm unemployed I'm doing this on a budget, so donations would be great.
I may even have something in my shed you need if you want to barter.
- Silverbullet
The other way to do it is as per Jonno's post here use the original Brumby flywheel, get the step machined from 23mm to 21mm and use all L series clutch kit including pressure plate and throwout bearing. This is the way I did it and it works great...well the few times I've reversed up and down the driveway that is I've used the L series clutch cable as well, and L series clutch pedal fitted to MY pedal box, to keep the pedal throw and effort required reasonable.
This way you don't have to mix and match clutch kit parts; just machine the flywheel and use all L series stuff Although if it is a tight budget then machining the flywheel might not be an option, unless you have a friend with a big lathe who can be bought with beer like I did
