Gen 2 ej22 ecu pin out diagram wanted
Hey all,
Does anyone have the pin outs of a gen2 na ej22?
Needing one to test if my ecu is fried or not.
Thanks
I should add it's a 3 plug ecu
Thanks
- vincentvega
is that correct, gen1 lib has 8bit ecm and gen2 has 16bit ecm? Best way to tell if you have series 1 or 2 is the year.
- vincentvega
pretty sure gen 1 series 1 aus had 16 bit ecuAlpineRaven wrote:is that correct, gen1 lib has 8bit ecm and gen2 has 16bit ecm? Best way to tell if you have series 1 or 2 is the year.
while jap had the 8 bit
dont know bout gen1 s2
i do know the tune changed power went from 100 to 95kw emitions got better and touque was a bit higher
and im lost with gen 2 bar series 2 wireing being the same as ej25 quad cam
