ej22 cam and crank timing events
AUSubaru Technical Manual. Collaborative Tech Manual for ALL Subarus.
mattl200
Post by mattl200 » Thu Mar 19, 2009 10:46 am
gday
looking for some info or a diagram for ej22 cam and crank timing marks
wanting to know the position of angle marks on the cam and crank wheels so i can program my new ecu
and if there the same as 1999-2000 ej20 cause thats in the program ej22 is not
the ecu is adaptronic
chears
Mathew
bluesteel
Post by bluesteel » Thu Mar 19, 2009 2:25 pm
v1-6 should all be the same
im pretty sure all the cranks are interchangable, and therefore crank sprocket
ive got a link and the sensor is called subaru v1-6
im running an ej25 crank with 2.2l block and im pretty sure its the 2l crank sprocker....
i have a good diagram in a manual of how they work if you need it...
mattl200
Post by mattl200 » Thu Mar 19, 2009 9:34 pm
that would be great johnney
ill have too see if it works and go from there
bluesteel
Post by bluesteel » Fri Mar 20, 2009 9:22 am
here we go...
mattl200
Post by mattl200 » Fri Mar 20, 2009 11:15 am
chears
thanks muchley
mattl200
Post by mattl200 » Sun Apr 12, 2009 7:58 pm
just posting this info for everyones benifit
while searching for something else i found the same diagram for an ej22
it looks like there the same havent confermed yet inn see if it starts
though the guys on the adaptronic forum think that the ej25 on the newer wrx has a differant set of marks
Return to “Tech Manual”
