Tuning 85 Brumby
Tuning 85 Brumby
Hey guys,
Anyone know of a web site that i can download tuning instructions as per subi specs. Car is bogging down on take off so wouldnt mind having a go myself before i send it off to the mechanics.
Cheers!
Cheers!
no, but take air box off, start engine in neutral, handbrake on , wheels chocked, make sure no kids around, have a look and listen to sound of carby sucking air and fuel, activate throttle cable to get off idle and see if you can see fuel squirting from accelerator pump plunger into venturi. it needs to squirt pretty hard to atomise, if its just a dribble - well you have prostate trouble - just jokin' - that's later. Assuming it is not a weber but original hitachi there is a sight glass window to view fuel level in float chamber. clean it and look at it running (engine , not you)
come back and tell us
- BaronVonChickenPants
- brumbyrunner
Hey guys, cheers for the advice to date. Checked the float level over the weekend and its sitting right in the middle which seems ok. As for the jet, it appears to be sraying a decent amount of fuel into the carby so it doesnt look like its short of fuel. Plugs are brand new and fine. Next step is to blow out the fuel lines. Ill let you know how i get on. Also, do you know of anyone in the Brisbane area who specialises in subaru brumbies???
Cheers Pawl.
Cheers Pawl.
