L series wheel bearing replacement
gday fellas, just wondering if someone has a file of how to do this? or can give me a quick run down of wat is involved?
do they need to be pressed out? do i need to remove c.v joint and hub etc?
for a front drivers side bearinbg
cheers batesy
cheers batesy
Hi Batesy, if it's a front wheel bearing, yeah you'll hafta get the old ones pressed out and the new ones pressed in, prolly easier to take it to a mechanic/suspension workshop. While you're there get them to inspect and replace joints,bushes and any other worrying items.
p.s. would also be a good time to get both sides replaced and machine the discs, i found out the hard way that renewing one side only leads to stressing the opposite bearing more but that's up to you.
Hope it works out for you!
we knocked some out with a hammer and punch not to long ago when an Lseries got done here.
and u cant exactly press em out.
the bearings go in one on each side and hit at a stop in the middle. so a press wont be that easy to use.
hammer and punch is easy
Wagon is no longer....
