Bushings
twilightprotege
Bushings
Post by twilightprotege » Sun Nov 09, 2008 5:04 pm
Just wondering if anyone has a complete list of available bushings for my Leone RX, specifically part numbers? Super Pro, Nolethane, whoever, more the better. Would be a good sticky or addition to a FAQ...
Post by El_Freddo » Mon Nov 10, 2008 4:19 pm
FROG will be the guy to contact about part numbers.
I've just ordered a set of rear swing arm bushes for my L, I don't have the quote with me but from memory it was something like $80 for a nothaline (or how ever you spell it) bushes.
twilightprotege
Post by twilightprotege » Tue Nov 11, 2008 10:08 am
will pm him, thanks.
still would be good to have a sticky with the various part numbers available is someone else has them???
BlackMale
Post by BlackMale » Tue Nov 11, 2008 12:01 pm
I have done the full replacement thing front and rear. I am not sure if i have kept all the paperwork though. I'll have a look for you when i get home and post up if i can find it.
twilightprotege
Post by twilightprotege » Wed Nov 12, 2008 12:52 pm
thanks to FROG, subaru part numbers:
21047GA312 FRONT LEADING ROD BUSHS X4
21047GA340 REAR CROSS MEMBER FRONT BUSH X2
21047GA491 TRAILING ARM BUSH X2
20401FA021 FRONT STAB BUSH X2
41022GA141 ENGINE MOUNT RUBBER X2
41022GA160 GEARBOX MOUNT RUBBER X2
21342GA131 REAR STAB BUSH X2
41322GA010 DIFF MOUNT BUSH X2
633124170 SHIFTER BUSH X4
633124180 SHIFTER BUSH X4
733146000 LEVER BUSH X1
633011330 LEVER BUSH X2
31260GA340 STEERING RACK MOUNT BUSH X1
31260GA330 STEERING RACK MOUNT BUSH X1
please note these are the subaru part numbers for my car, VIN specific. it's a 1987 Leone RX, VAF (so 3 plug ecu), manual.
let's add some more part numbers from other manufacturers to get a complete list!
