How to straighten the camber on brumby
subarubrumby
Post by subarubrumby » Tue May 03, 2011 5:37 pm
question for the pro's out there, how can i straighten the camber on my brumby ? and is there any coilover i can fit to a brumby ? what do i have to upgradee ?? cheers lads.
Post by sven '2' » Tue May 03, 2011 6:35 pm
What is the rest of your set up? Lift kit?
What are you trying to achieve?
A well aligned Brumby actually drive pretty well - certainly better than my L ever did!
subarubrumby
Post by subarubrumby » Tue May 03, 2011 6:48 pm
lowered in the rear end, choppies in the front,
to achieve.. i hate the ugly camber and really love cars with negative camber, and trying to achieve the drift look on the brumby, cheers
Post by sven '2' » Tue May 03, 2011 6:51 pm
Can only think of the Crossbreed kit.
Sorry, have spent my life lifting Subies, not lowering them!
subarubrumby
Post by subarubrumby » Tue May 03, 2011 6:57 pm
crossbreed kit is how much... :( and i was hoping there was a strut that could bolt in the brumby then i get ULTRA LOW KING SPRINGS and have straight wheeeels :) no camber. maybe a lil negative.
Post by TOONGA » Tue May 03, 2011 7:32 pm
another way to get negative camber in a brumby is using L series lower arms
subarubrumby
Post by subarubrumby » Tue May 03, 2011 7:36 pm
thats what i want to hereeee TOONGA :)
to clarify, what is a L series ?????
Post by TOONGA » Tue May 03, 2011 7:50 pm
the L series is the model between the MY model and the liberty, more often than not it is the chosen model that is lifted and then has an EJ motor put in it.
the L has longer control arms and with very little modifying can be put into an MY model
subarubrumby
Post by subarubrumby » Tue May 03, 2011 7:54 pm
so im taking it my brumby is a ' MY ' model ? mines like the exact one in your lil picture thing that flicks throught those pictures really quick hahaha, sorry for being a dumb azz.
Post by TOONGA » Tue May 03, 2011 8:37 pm
Yes thats correct the brumby is an "MY" or "MV" model depending on who you talk to
subybrumby
Post by subybrumby » Tue May 03, 2011 10:16 pm
Installing the L lower control arms will give you the negative camber you want but comes with other issues that you may or may not like. The front track will be a bit wider than the back and the front wheels will be pushed a bit further forward into the wheel well..looks a bit odd from side on. If you do a search on the forum there has been plenty written up about it. I ventured this way myself but went back to the brumby setup after encountering the issues I mentioned plus problems trying to mount L brakes on brumby hubs etc etc .....
velocityboy
Post by velocityboy » Wed May 04, 2011 7:32 am
Have you got posotive camber on both sides? I have lowered a couple of brumbys before and their can be a problem.
subarubrumby
Post by subarubrumby » Wed May 04, 2011 8:41 am
when you say track, do you mean you look at it from behind and the fronts will be out wider then the back ?? and the wheels would be toward the front of the wheel arches more then the middle ?? i should be okay with that :) and yes i got postitive camber both sides...
subybrumby
Post by subybrumby » Wed May 04, 2011 6:21 pm
Yes, the front wheels will be out wider than the back, not a lot but ...
subarubrumby
Post by subarubrumby » Wed May 04, 2011 9:35 pm
oh yeah thats all good i rekon it makes it look tuff :)
