Post
by AlpineRaven » Sun Feb 10, 2013 8:38 am
Might be easier to tell -
3 things:
1) Does the car have a button for raise and fall on the left from steering column?
2) Pop the bonnet, you'll see the strut towers, there should be either a black plastic covers, remove them - do you see any hoses/tubes going there? or just standard nut with bolt poking out and no hoses?
3) If not sure about the strut towers - jack the car up and have a look at the spring section, do you see a black rubber bellow behind the coil springs, if it had standard strut you'll see plastic loose cover over the struts (prevent dust from going in the struts).
1996 Liberty Wagon - SkiFX AWD 5MT D/R, Lifted.. Outback Sway Bar, 1.59:1 Low Gearing see thread:
1.59:1 in EJ Box Page
