3 inch lift kit Q. and A.
BRUMBI
Post by BRUMBI » Sun Jul 08, 2007 11:43 am
hey just about to start the front end of my brumby is there any tips on how to do this
also i heard you have to wind down the front springs if there already raised and will air con get in the way
thanks kai...
84 MY Sportswagon
92 Brumby
87 Rx Turbo
BRUMBI
Post by BRUMBI » Sun Jul 08, 2007 12:44 pm
just wanted to mainly know about the springs if the have to be wind down
84 MY Sportswagon
92 Brumby
87 Rx Turbo
90brumby
Post by 90brumby » Sun Jul 08, 2007 1:53 pm
mine are half way up if its ny help
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by AndrewT » Sun Jul 08, 2007 6:48 pm
There is an installation guide for fitting a lift kit to an MY buried somewhere in the BYB website.
BRUMBI
Post by BRUMBI » Mon Jul 09, 2007 9:11 am
yeah it dosent say on the guide , ohwell will just have to give it a go anyway
thanks for the help
kai
84 MY Sportswagon
92 Brumby
87 Rx Turbo
brumbyrunner
Post by brumbyrunner » Mon Jul 09, 2007 3:52 pm
BRUMBI wrote:hey just about to start the front end of my brumby is there any tips on how to do this
thanks kai...
Installing a lift kit is pretty basic. The only problems are if the kit does not allow for things like radiator hoses, steering angles and the engine torque rod. And you will probably have to adjust your gearstick and 4WD lever to stop them from hitting the tunnel. Your exhaust will most likely foul on something and will also need adjusting.
I would leave the adjusters wound all the way down. Winding them up increases your front driveshaft angle. If you need more tyre clearance, use more body lift. If you need a higher spring rate, change your springs.
BRUMBI
Post by BRUMBI » Mon Jul 09, 2007 5:52 pm
well that cleared it up i think i will wind them down, the exhaust is alredy stuck, but the kit came with all the gear so should be alright, ive rounded off 3 out 4 of the crossmember bolts so its going to get messy..
btw what do ya do for a sump bash plate i dont think the old one will fit, any idears?
84 MY Sportswagon
92 Brumby
87 Rx Turbo
Post by Alex » Mon Jul 09, 2007 8:50 pm
on my l-series i slotted the holes and made afew brackets(and smashed the crap out of the sump guard) got it to fit very nicely..
EDIT: yes it is gold
note the nut and bolt at the rear left of the sump guard...one on either side makes it strong as all ****
BRUMBI
Post by BRUMBI » Tue Jul 10, 2007 6:38 pm
i will make up some brakets sounds good, cheers for the help think i might leave it black tho
84 MY Sportswagon
92 Brumby
87 Rx Turbo
