Koni Struts V soon !
discopotato03
Post by discopotato03 » Thu May 22, 2008 5:50 pm
Hi all , my suspension mentor has the new Koni rear dampers and threaded sleeves at last . They are 50mm diameter body with adjustable rebound , the steel sleeves where the lower eye bolt fits through needs to be changed to suit an L series A arm .
I think the lower mounting bracket plates may need to be modified to suit the larger than std diameter damper bodies .
More as it happens , cheers A .
