History:
Noticed that the suspension would not go into "Hi" mode, then ride in front was rough, losing pressure, fault code kept flashing up on switch after about 10 or more minutes driving
Self-diagnosed faults in the system to codes 7, 8 & 9. Codes 7 & 8 are rear solenoid valve output continues for 10 minutes and 9 is the compressor relay output continues for 10 minutes.
Couldn't seem to find any leaks in the system, so took it to Subaru how had trouble getting the system to charge and came up with "Replace Compressor" diagnosis.
Went for a 2nd hand compressor from the wreckers at first (ouch!), and all that seemed to happen is that I lost all the air out of my front struts, but back ones remained on a relatively high setting.
Then went for new genuine compressor (ouch, ouch!), and bingo, no difference.
Noticed that at least the front solenoids were not opening when height control set to high, manually opened them with +12V into solenoid connectors and front struts raised quickly to very high setting (while compressor was running). Also noticed solenoids not opening to release air when height control set back to normal. At least I can drive it a bit now.
Tried removing fuse, disconnecting battery and resetting Engine ECU in a vain attempt to reboot the suspension control unit or reset it. Since is a separate unit I don't this would work anyway. Codes in suspension ECU cleared (as expected), same ones return after driving for a while.
Replaced Control unit with wreckers number (ouch!) and no difference, tending to not want to try genuine new unit as the price I was quoted was $4154! Yes. I didn't think that was right either. An old Subaru parts CD I have had a completely different part number that was about 1/7th that price but didn't appear in dealers book / dodgy diagrams?
Running out of ideas now...
*comments about changing to conventional suspension will be ignored
