Liberty CV to Brumby axle
Posted: Wed Sep 17, 2008 5:10 pm
by 2happypigs
Hi, can anyone tell me if the inner and outer CV joints will fit onto a Brumby axle?
This is for a trike project .
I am trying to achive a thinner wheel base.
I am using SVX motor and gearbox with Liberty hubs.
Thanks for the help.
Rusty
Posted: Wed Sep 17, 2008 5:19 pm
by vincentvega
cant help you with your driveshaft question, but how are you planning on using the gearbox to only drive one axle?
if you were to fit a liberty 2WD auto rear end to the SVX 4WD auto box it would work well for you. H6 trike - kickass
Posted: Wed Sep 17, 2008 5:30 pm
by 2happypigs
Thats exactly what i am doing
When i get a bit futher on I will start to post some pics
Rusty
Posted: Wed Sep 17, 2008 5:40 pm
by Jeff
Are you talking brumby front or rear?
Posted: Wed Sep 17, 2008 5:52 pm
by vincentvega
front if i understand the gearbox setup correctly ;)
Why dont you just have some liberty shafts shortened to give whatever track you want.
Posted: Wed Sep 17, 2008 7:23 pm
by the gumbi brumby
should work just about any outer or inner will go on a sharft i know a fella that worked for drueline servises
Posted: Wed Sep 17, 2008 8:12 pm
by 2happypigs
I rang driveline servics and they said they could not cut it down for me.
all I need to know is, are the splines on the on the Brumby shaftes the same as the Liberty. IE number of teeth and diameter.
I beleve the Brumby shaftes are about 100mm shorter. I was looking for a 5 inch shorterning but 100mm will do.
Thanks Rusty
Posted: Wed Sep 17, 2008 8:21 pm
by the gumbi brumby
there is a clip inside the cv slide it off assembel how you greese it up new boot away you but i dont know about cutting and welding
Posted: Wed Sep 17, 2008 10:07 pm
by Pommiebrat
Mate, simple answer is yes you can fit a Liberty CV to a Brumby axle. I know - I've just done it in order to fit a different gearbox to my Brumby. Takes about 10 mins a side.
John
