Liberty Airbag Compressor as tyre inflator?
crundle
Post by crundle » Tue Nov 25, 2008 5:43 pm
Not sure that this is the right thread for this, but wondering if anyone has used an old working airbag compressor as a tyre inflator for an L series?
I think the compressor is found under the passenger side behind the front tyre panel, anyone know exactly where it is?
Seems like a good idea, and I have recently had the missus' liberty converted to normal struts, so I gather she wont notice if it goes missing!
cheers,
crundle
'91 carby L Series Wagon (White) - Stock standard - for now... ;)
vincentvega
Post by vincentvega » Tue Nov 25, 2008 6:10 pm
compressor is inside the passenger guard.
its a low volume pump, and would take AGES to fill a tyre. this has been discussed a heap of times. try a search
if you are converting to standard suspension ditch all the air gear. there is probably about 40kg of crap inthe car you dont need.
Outback bloke
Post by Outback bloke » Tue Nov 25, 2008 8:09 pm
I did it and it although it worked it was a waste of time. As VV said, it is very slow. You could pump your tyres up faster with a foot pump.
crundle
Post by crundle » Wed Nov 26, 2008 12:41 pm
Thanks for the heads up about it not working well. I have noticed that other threads are advocating using the air conditioner pump for the same purpose, so I might investigate going down that path instead.
cheers,
Outback bloke
Post by Outback bloke » Wed Nov 26, 2008 1:58 pm
That does work quite well. Subarute had it set up like that in one of his cars.
Wilbur
Post by Wilbur » Wed Nov 26, 2008 2:24 pm
Look up 'endless air' through a seach engine for ideas on that one.
BlackMale
Post by BlackMale » Wed Nov 26, 2008 2:52 pm
crundle wrote:Thanks for the heads up about it not working well. I have noticed that other threads are advocating using the air conditioner pump for the same purpose, so I might investigate going down that path instead.
cheers,
FYI Subarino has done this as well (sorry to throw you in it Dave).
tex
Post by tex » Thu Nov 27, 2008 9:12 pm
Its a low volume pump granted but does anyone know what kin of preasure its capable of?
87 targa brumby (Neglected),
+ others.
d_generate
Post by d_generate » Fri Nov 28, 2008 1:27 am
cheers,
I had the aircon compressor in my old 60 series set up as a pump, it would inflate a 12.5x33x15 to 32lb from flat in about 60sec @ 1,200 rpm, absolutely brilliant, just chucked a bit of oil in it every now & then.
T'subaru
Post by T'subaru » Fri Nov 28, 2008 2:39 am
I ran across a tube bumper somewhere that was set up as a reserve air tank. Do not recall capacity, etc. Just an idea.
Cheers, mark
tex
Post by tex » Fri Nov 28, 2008 9:20 pm
There is an aluminium fabricator in hall that does this with some of his trays plus water storage aswell but id prefer a small compressor incase you get a few flats plus then you hold more water!
+ others.
