l series steering linkage
Posted: Sat Nov 29, 2008 9:09 pm
by 89lseries
hey guys
the steering linkages on end of steering column have sum play in them. . they are small uni joints, however they do not appear to be replaceable. does any one have any idea of where i can get some new ones or how to replace the uni joints? car is a late 88 lseries non power steering 4wd wagon
cheers
89lseries
Posted: Sun Nov 30, 2008 2:44 pm
by Subafury
try a wreckers. loosen the bolts then side it one way and you should be able to get it off.
Posted: Tue Dec 02, 2008 4:41 pm
by subalex
As Subafury said. It's easy to take off. Just make sure you mark a cog on each of the two shafts so that when you put it back together it's all straight. Also, when putting it back together you must make sure that the flattened section of the steering column shaft lines up with the path that the bolt will go or you can strip the thread of the bolt by trying to screw it across the splined section.
Mine has some play in it too. The wreckers is a good source for a new one... cheapest way to go and you'll easily be able to test a good one in the car. I priced getting the CV joints pressed out and fitted with new ones by a CV specialist... $100 he said. It's about the same cost for a new one sent to you if your car is lifted and requires a lengthened part.
Posted: Thu Dec 04, 2008 9:24 pm
by 89lseries
cheers fellas
had thought bout wreckers was just seeing if there was any other options
Posted: Tue Dec 09, 2008 2:16 pm
by Suby Wan Kenobi
Had a recent steering shaft seemed like it was stuffed but the cruch area was filled with small stones so it wouldnt tighten properly a clean and a carefull application of new grease and it was all good as new.
It can also be the rack not the steering extension that has the play
