Brumby strut tops
Brumby strut tops
I've got a crossbred kit and some JDM struts and I have assembled them as I can figure out from the instructions, which leaves me with a couple of questions.
1. Am i supposed to replace the standard brumby washer with that pack of 3 or are they supposed to all be in there (4 washers) as i have found the top rubs on the upper spring seat with 3 and with 4 washers there is a rather large gap for dirt and dust to get in?
2. The brumby tops have no berrings, is there a replacement with berrings or are they really not needed?
3. Has anyone got any real information on modifying the chassis for the 3 bolt strut tops? from my research people seem to think its not a good idea.
Thanks, Prunes
Thanks, Prunes
2002 Impreza GX Hatch: Dents, Scratches, Missing inside wheel arch, Barely attached front bumper.
1983 Brumby: Currently being rebuilt.
- brumbyrunner
I think I may have taken a photo when I did mine if you PM me your Email address I'll try and dig it out for you,
I seem to recall Emailing jeff about making this part of the instructions a little clearer!
87 targa brumby (Neglected),
+ others.
+ others.
- SUBIIE
hmmmm,
mate i had exactly the same problem. I found theinstructions hard to follow (for a dummy).
And yeah i have photos (plus an almost 80% complete fit guide) if you want to email me at [email protected]
but the three washers go in place of the imprzza round washer so you have imp strut and spring with 3 washers with lube on the then the MY strut top.
make any sense?
by the way you are going to need to bash the strut tunnel to get them to fit properly!
make any sense?
Makes me feel better knowing I wasn't the only one to massage these into place, I was almost going to go coil overs instead!SUBIIE wrote:by the way you are going to need to bash the strut tunnel to get them to fit properly!
+ others.
+ others.
