how to wind up frount struts
Posted: Mon Feb 02, 2009 5:35 am
by dj fbi
could any tell me how to wing up my front struts so i can get a little more hight the back struts look like they have been done,the back sit's up a lot higher,i have low profiles on at the monent but has decided to put bigger tyres on her,also if struts are wound all the way up what are the biggest tyre size i can put on,the rims are 14in.thanks guys.
Posted: Mon Feb 02, 2009 9:43 am
by AndrewT
Biggest tyres available for 14" rims are 27". You really need a body lift kit to run these though.
It's very unlikely you have adjustable height front struts, so you can't wind them up. If you want some extra heigh from the front suspension you need to get new springs.
Posted: Mon Feb 02, 2009 12:02 pm
by shuffbag
almost all my subies have had adjustable front, just look below your front struts base plate that the spring sits in. if there are two nuts hanging under there just wind them up (22mm i think) its not much you gain but every bit helps.
