Coil Springs on '84 Leone MY Coupe
Rabbitoh
Post by Rabbitoh » Wed Mar 11, 2009 8:09 pm
Has anyone ever fitted rear coil springs on a MYLeone Coupe (front wheel drive). I am sick of it sinking when my daughter's overweight friend sits in the back. I already have heavy duty shocks on it but she breaks through that barrier without any trouble. I would imagine an L series front wheel drive rear type setup would be the answer if it can be converted. Any help appreciated.
Post by AndrewT » Wed Mar 11, 2009 8:33 pm
You may want to try winding up the torsion bar. This can be done by adjusting the big bolt under the rear seat I beleive. Or get the fattie to sit in the front :)
Post by Gannon » Wed Mar 11, 2009 9:40 pm
2wd leone's dont have the torsion bar adjustment. Thats why im putting the 4wd rear in mine.
Im sure somebody has put L rear springs in a MY, i think it was somebody with a Brumby, maybe Phizinza or Mattims
Phizinza
Post by Phizinza » Thu Mar 12, 2009 8:14 am
Not me, although I did put L rear springs in the front... A couple of years back there was a topic on this on USMB. There were a few people that had it and liked it. Just used the L series strut in place of the MY shock with a modified top bracket.
daza
Post by daza » Thu Mar 12, 2009 8:32 am
I've seen it done on a Brumby, The owner had factory L series mags but they wouldn't fit with the L struts in.
He went back to Desert Rats and apparently was happy.
Daza.
:D
Matt
Post by Matt » Thu Mar 12, 2009 6:19 pm
It can be done i have them on my Brumby. You just need a simple bracket to adapt the top of the strut. The bottom just bolts up. But it does make it alot stiff in the back, almost to stiff.
"Claudia"
Rabbitoh
Post by Rabbitoh » Fri Mar 13, 2009 5:06 pm
Matt wrote:It can be done i have them on my Brumby. You just need a simple bracket to adapt the top of the strut. The bottom just bolts up. But it does make it alot stiff in the back, almost to stiff.
Thanks for that. I'll give it a shot.
Matt
Post by Matt » Fri Mar 13, 2009 9:59 pm
No drama's i should have mentioned before you will need a welder and angle grinder.
"Claudia"
nncoolg
Post by nncoolg » Sun Mar 15, 2009 11:34 am
Matt, can we have pics?
Matt
Post by Matt » Sun Mar 15, 2009 9:03 pm
This isn't the best pic but you can see what you need to do. I will try and find some more or take some later.
"Claudia"
nncoolg
Post by nncoolg » Sun Mar 15, 2009 9:34 pm
So, what do you do with the torsion bar?
Phizinza
Post by Phizinza » Sun Mar 15, 2009 9:49 pm
The idea is leave it, just adding more spring to the system. Really I think its stiff enough already. I'd get some pump up shocks (what I had on my brumby) and when the load is more then 400kg just pump them up and you'll raise it back up another 2+ inches.
for the orignal question though, you might want to try new torsion bars? They do fade and sometimes need replacing.. How low verses the front does the rear sit when the car is sitting with nothing in it on the level? pic?
