L Series lower control arms
TW83
Post by TW83 » Sun Apr 26, 2009 11:40 am
I have been reading the threads about using L series lower control arms on the MY/Brumby and cant find a straight answer to "are L series axles also required?" (mine is already fitted with an EA82 5 Speed)
I have also been hunting for rear diff mount bushes and had no luck finding p/u aftermarket so will have to go down to the Subi dealer Tuesday.
The diff hanger has a bend in it on the left hand side that looks like the diff has twisted it. I haven't found a striaght one yet - was that how they came from the factory?
Matatak
Post by Matatak » Sun Apr 26, 2009 11:56 am
Lseries axles with either an MY Outer CV put on, or installing the Lseries hubs and bigger brakes with them.
Tie Rod ends also need a bit of work to find one a bit longer.
also the Radius Rods.
Diff hanger should be straight.
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
TW83
Post by TW83 » Sun Apr 26, 2009 12:26 pm
Thanks Matatak,
I think I will have a go at reinforcing the diff hanger.
Longer tie rods off another Subi?
TW83
Post by TW83 » Sun Apr 26, 2009 12:34 pm
I am in Bunbury and there is only 1 gutted out brumby at the wreckers! Do you know of any wreckers in Perth that have a reasonable number of cars ?
Post by steptoe » Sun Apr 26, 2009 12:42 pm
do some searching in here re tie rods - think early Camry was the answer
Bluesteel, Brumberty search their old posts
Matatak
Post by Matatak » Sun Apr 26, 2009 12:42 pm
i managed to mix and match tie rods off another Subaru but they had to go into my EJ rack which requires different ends to an MY rack in the first place.
ive got parts of my old wagon if you need anything ?
Point
Post by Point » Sun Apr 26, 2009 1:24 pm
try this link
showthread.php?t=4369
and there should be a slight bend right near the end of the rear diff hanger on the lhs
98 Forester GX
02 Forester XS Luxury
mattl200
Post by mattl200 » Sun Apr 26, 2009 11:53 pm
lseries tie rods are too long but if you tap the thred longer m14x1.5 i think and cut some off the end there fine
power steer and non power steer rack ends are differant in the thread th the rack (one male one female) for lseries dont know bout my
TW83
Post by TW83 » Mon Apr 27, 2009 8:58 pm
Thanks for all the help.
I was just playing around today and spaced the MY radius rods to push the wheels forward about 10mm. Even this small increase made a noticeable difference.
As soon as it is registered the L Series bits will be going on.
