brumby lift kit pictures needed
Posted: Tue Jun 30, 2009 9:45 am
by TOONGA
could some one with a lift kit installed on a brumby please post pics of all relevant areas that need to be lifted
every time I look for pics on the net I get pictures of lift kits in a neatly arranged pile on a lovely white background or sites that show lifted L series and libertys etc but no brumby or MY wagon models
thanks in advance
Posted: Wed Jul 08, 2009 8:04 am
by SUBIIE
Posted: Wed Jul 08, 2009 2:13 pm
by TOONGA
email sent awaiting your reply
Posted: Thu Jul 09, 2009 1:30 pm
Why do you need pictures? Do a search on the forum for Subyruby and lift - we installed a two inch lift in his MY wagon a few months ago, there might be some pics there that will help you out.
If you need them to see how it all fits together to make your own you either need a parts car to build it on or to have a look at one thats already lifted - but have a look in the 'flesh' as photos might not give you exactly what you need...
Posted: Fri Jul 10, 2009 10:48 am
by TOONGA
Im looking at making my own out of aluminium block and stainless steel plate and I want to ensure I have every fiddly bit covered
Posted: Fri Jul 10, 2009 4:58 pm
Yeah fair enough - the two fiddliest bits I would say are the strut towers for the front and the steering shaft.
The rest are just blocks with holes drilled in them. The front crossmember is a single block with two holes and same for the mostache bar support bracket's blocks. The rest are a block with a hole and a longer bolt...
Posted: Wed Aug 05, 2009 8:46 pm
by wrxer
toongs i got a steering column knuckle from a liberty will suit about 1 inch front chassis lift if you want. someone may be able to confirm. im not sure as i may have moved steering column in or out. outback ones are longer
Posted: Thu Aug 06, 2009 12:34 pm
by TW83
You can come have a look at mine if you want. I am in Australind as well.
Posted: Fri Aug 07, 2009 7:47 pm
by TOONGA
ok would be good thanks
