DIY - Strut Lift tops
Post by AlpineRaven » Sun Jul 05, 2009 9:21 pm
Is there any detailed information or diagram about making strut lift tops for Liberty on here - I've searched but came up nothing. I'm looking at 2" or 3" tops. I already have the blocks but it just the tops I need to make.
phillatdarwin
Post by phillatdarwin » Sun Jul 05, 2009 9:25 pm
i have read a thread about it on hear some wear .
Post by AlpineRaven » Sun Jul 05, 2009 9:28 pm
phillatdarwin wrote:i have read a thread about it on hear some wear .
If you give it correct lift ie. 3" lift blocks and 2" tops with outback struts then no it doesnt - dunno about l series.
Post by AlpineRaven » Sun Jul 05, 2009 9:51 pm
Found couple of threads... is it 6-7mm offset per inch for the front. 3-4mm for the rear?
So, if I wanted 3" in front it would be 18mm offset? and 2" in rear would be 6mm offset.... that sounds a lot?
Post by AlpineRaven » Sun Jul 05, 2009 9:53 pm
Maybe 3" is a bit much?
phillatdarwin
Post by phillatdarwin » Sun Jul 05, 2009 10:11 pm
u have to put the off set in to mach to factory strut setting.
daza
Post by daza » Mon Jul 06, 2009 8:18 am
... or you could buy the strut tops from the Back Yard Boys!
Daza.
:D
