It is about 90mm longer than a standard 'L' series stut.
10 points to anybody who can guess what the struts are from......
Try a biger make of 4wd.......brumbyrunner wrote:Suzuki Vitara?
Sounds like the doner car might be heavier.AndrewT wrote:How come it needed a custom spring if it's a factory shock? Couldn't it just use the matching factory spring?
Xtreme_RX wrote:Try a biger make of 4wd.......
Stuart you would be correct!brumbyrunner wrote:I would have said factory Prado/Hilux.
Semi-off-topic: is that absolute about spring spacers? Nolathane sell 10mm soacers for coil sprung live axle Falcons with no mention of legality.Xtreme_RX wrote:Spring spacers are a dodgy way of doing things. + they are illegal & do not conform to ADR spec.
The Nolathane ones for the falcon are a spring seat replacement. They replace the original rubber ones...GOD wrote:Semi-off-topic: is that absolute about spring spacers? Nolathane sell 10mm soacers for coil sprung live axle Falcons with no mention of legality.
Dane.
