Page 1 of 2
ausubaru lift kits.
Posted: Tue Aug 25, 2009 7:13 pm
by Learner
hi all. was wondering if any one that has a 3ih lift on a l could take photos of it installed/
not sure what goes where or if i got all the parts
Posted: Tue Aug 25, 2009 8:05 pm
by Outback bloke
Email Dave at csm101ATausubaru.com
Posted: Tue Aug 25, 2009 8:19 pm
by guyph_01
Ive got a 3inch on my car, I'll put some pics up if you want. I'll do that tomorrow in day light:)
Posted: Wed Aug 26, 2009 4:41 am
by Learner
thanks would love that!
Posted: Thu Aug 27, 2009 3:02 pm
by Learner
tried emailing dave but no answer
Posted: Thu Aug 27, 2009 3:17 pm
by Bumpty
NB: Sometimes i am away for a few days so be patient.
Quoted from the sticky in this section.
Posted: Thu Aug 27, 2009 9:23 pm
by AlpineRaven
If someone has pictures to show, it would be good if someone could upload pics here for future reference?
Posted: Sun Aug 30, 2009 10:59 pm
by Learner
anyone? just need the pics
Posted: Mon Aug 31, 2009 12:12 am
by AndrewT
Try searching around for pics, theres bound to be plenty. But in all honesty you don't really need em. Once you have the lift kit sitting near your car and you look at things, it's very obvious where it all goes. If you get stuck during the install just post up a question and somebody will point you in the right direction. Did you have any particular questions about something to do with the install?
Post up a photo of what parts you have and we can tell you whats missing...
Posted: Mon Aug 31, 2009 3:58 pm
by guyph_01
Hi,
sry for the wait but i have been very busy with uni assignments.
Ok First of all i didn't take pics of the front sturt liftkit as its impossible to get the cam up there. but on my kit, it had arrows on it and they had to point inwards.
This is a pic of the block that goes on the engine crossmember.You can also see the blocks for the radius rod mount.
This is a pic for the blocks that go on the radius rod mount.
This is a pic of the blocks that go on the uni jouint on the drive shaft.
This is the pics of the blocks that go on the rear crossmember
Posted: Mon Aug 31, 2009 3:59 pm
by guyph_01
This is the pic o the block that goes on the rear moustache bar.
This pic is not from my car but its the lift for the rear shock. Its similar to mine.
Obviously those are pics of only one side on the car, and the other side, the blocks are indentical:)
Hope those pics help you and can help as a futur referance.
Posted: Mon Aug 31, 2009 5:23 pm
by Learner
so the rear crossmember's front bushes' bracket is deleted?
Posted: Mon Aug 31, 2009 5:58 pm
by Learner
well thank you so much for the pics. isn't there a set of blacks for the gearbox as well?
my kit is a bit different where the diff is lowered at it's mounting points which i like better.
so the diff is covered.
i got the leading rod covered as well (though i am MISSING 2 BOLTS),
front crossmember covered
as for the rear, i got the rear crossmember bush covered,
but as for the front one, do i just delete the plate? i got the block for the bush, but not the plate!
back to the gearbox, seems odd not to have the gearbox lowered! isn't it suppose to be lowered? if so i'm missing those blocks.
thank you for your help!!
Posted: Mon Aug 31, 2009 7:26 pm
by openflame06
Has anyone heard that lifting in NSW is now very hard to do? Apparently new RTA rules say that you cant go more than 5% of original height or something.
Posted: Mon Aug 31, 2009 8:30 pm
Learner wrote:well thank you so much for the pics. isn't there a set of blacks for the gearbox as well?
The gearbox is lowered with the radius rod blocks, as the gearbox crossmember uses one of the bolts on each side to support it. For a visual the gearbox crossmember is the yellow bar that runs out of pic on the right with the gearbox shown in the background (thanks Guyph for the pic):
guyph_01 wrote:
That should solve that problem.
Posted: Mon Aug 31, 2009 8:40 pm
by Learner
isn't there a gearbox support toward the rear?
Posted: Mon Aug 31, 2009 8:55 pm
by AlpineRaven
Learner wrote:isn't there a gearbox support toward the rear?
yep the big yellow part is the gearbox support...
Posted: Mon Aug 31, 2009 8:58 pm
There's only one gearbox crossmember. Put your subi on a set of ramps or jack stands and take some time looking at the underbody - get up close and personal (not that personal!), you should be able to work out what's there and what you think is there...
Then bust out your lift blocks and see how they'll fit - work out where the missing bolts are from or if the original ones are used.
The liberty uses a sideways H gearbox crossmember...
Posted: Mon Aug 31, 2009 9:01 pm
by Learner
think i got it all covered. gotta have a look tomorrow. will have to pick up those 2 bolts before i install. thx heaps for the help
Posted: Mon Aug 31, 2009 9:57 pm
by AndrewT
There is usually a thin crossbar further towards the rear of the gearbox but this isn't actually required - it doesn't hold anything up. It's just there to catch the tailshaft incase it falls off the car, so it doesn't dig into the grond and catpault you into the air (I think it would actually just fold the tailshaft in half really, they aren't that strong). I havn't seen anybody actually bother to drop this down, it just gets chucked away usually.
If you have an automatic L series then I think you will have a rear support crossmember here which would need to be dropped down.
