Custom Struts - Liberty and Forester
- Outback bloke
Who here that has an Gen 2 Outback or Forester or uses Outback struts in their Liberty would be interested in some struts that will give more travel and are longer to replace the lift kit strut top? They are good quality struts and will be roughly the same price as buying genuine struts.
I am going to be getting a set for My Gen 4 designed which will cover the Gen 3 and 4. If there is interest I will look at getting the Gen 2 and Forester done as well.
- brumbyrunner
- Outback bloke
- vincentvega
- bobbyjimmy
- vincentvega
Brett how are you going to solve the camber problem going to taller struts with no offset lift kit strut top?
You can obviously change the angle of the holes where they bolt to the hub but then you will have your tyre rubbing on the strut in most cases.
Can you make an offset strut top somehow?
What was the deal with the offset correction?
With Gen 3 Liberty/Outback is completely different design from Gen 2 Liberty/Outback, on that day I was looking at this Gen 3 Liberty at the wreckers I didnt really pay 100% attention on the rear hubs, but to me, It looks like you could change from gen 2 rear hubs to Gen 3 area to enable to use Gen 2 struts in Gen 3. Is that possible?
I've had Outback struts with Liberty springs (standard outback springs and liberty springs are the same) in my Liberty but for 2 months now its back to standard (regretted that Ive gone back to standard height)
