Lower my03 H6 outback
njsdata
Post by njsdata » Sat Jan 16, 2010 1:55 pm
Hi everyone,
I am a newbie here. Excuse me if this is in the wrong thread. I want to lower my BH H6 outback to the equivalent height of a BH Liberty. Has anybody done this or do you know what is involved. (struts, springs etc)?
Thanks in advance.
Post by Gannon » Sat Jan 16, 2010 2:52 pm
The outback has lift blocks under most of the suspension mounting points and by removing these, it may resume the height of a normal liberty. I believe you will also need Liberty struts and springs
Post by AlpineRaven » Sat Jan 16, 2010 3:07 pm
Suparoo wrote:The outback has lift blocks under most of the suspension mounting points and by removing these, it may resume the height of a normal liberty. I believe you will also need Liberty struts and springs
Correct plus spacers as well, suspension swap etc.
njsdata
Post by njsdata » Sat Jan 16, 2010 9:21 pm
AlpineRaven wrote:Correct plus spacers as well, suspension swap etc.
Thanks Guys. Forgive me for being thick but what are the spacers and where are they located relative to the struts/shocks/springs?
Post by AlpineRaven » Sat Jan 16, 2010 9:47 pm
njsdata wrote:Thanks Guys. Forgive me for being thick but what are the spacers and where are they located relative to the struts/shocks/springs?
Spacers can be found on cross members in rear and fronts (between chassis rail-cross members), they're about 35mm thick.
bobbyjimmy
Post by bobbyjimmy » Mon Jan 25, 2010 3:11 pm
As above, spacers are on the Frt & Rr Crossmembers and the G/Box crossmember.
You also need to swap out the steering uni joint for a Liberty one.
Easier to get a set of coilovers, or just swap in Liberty/Legacy struts (get Bilsteins if you can) and Whiteline (or similar) lowering springs.
I had Bilsteins with Whiteline "Control" springs in my 02 Outback but sold them and got a set of Tein Flex coilovers - wish I did this in the first place.
In a few weeks or a month or so, i'll be swapping the g/box and diff (GT Forester 4.44 ratio with LSD rear) and steering rack (Bugeye STi) along with a couple of bits and pieces, and will be taking/grinding out the spacers then, if I remember i'll take pictures.
