Longer Struts?
drof351
Longer Struts?
Post by drof351 » Wed Mar 10, 2010 7:49 pm
Hi,
I have a 92 L series, wondering if you can get 3 inch longer struts or inserts for it?
Thanks
drof351
Post by drof351 » Wed Mar 10, 2010 10:36 pm
From what I've found hilux/prado struts fits the rear, not sure about springs tho, and you can modify the front struts to take longer commodore inserts?
Post by Alex » Wed Mar 10, 2010 11:34 pm
how do you mean exactly?
remember l-series is like a coil-over shock design in the rear.
you can get shock tops yes.
drof351
Post by drof351 » Thu Mar 11, 2010 8:33 am
Yeah read somewhere you can run commodore strut inserts in the front coil over strut assembly, with minor modification and hilux struts/shocks in the rear which are 90mm longer. Then with a body lift they will bolt to the factory position not needing blocks on top of the struts. Just after the exact struts to get.
thanks
