outback struts on liberty?
Phizinza
Post by Phizinza » Tue Jun 29, 2010 1:54 pm
Will gen3 outback struts bolt onto a gen1 liberty?
Post by AndrewT » Tue Jun 29, 2010 1:58 pm
Fronts yes, rears no.
Gen3 has multilink rear end which is heaps different.
Captain Obvious
Post by Captain Obvious » Tue Jun 29, 2010 4:39 pm
riksta on here has done this!!
Post by Alex » Tue Jun 29, 2010 5:54 pm
i thought gen3 also had two bolt strut tops in the rear where as gen1 has 3?
vincentvega
Post by vincentvega » Tue Jun 29, 2010 7:53 pm
what brian means is riksta has lifted a gen3 using gen3 parts..
Post by AlpineRaven » Tue Jun 29, 2010 9:50 pm
tops will but you cant unless you replace the rear hubs etc etc
vincentvega
Post by vincentvega » Tue Jun 29, 2010 10:02 pm
say what?
mate you need to start proof reading before you hit the post button
Post by AndrewT » Tue Jun 29, 2010 11:25 pm
yeah, as I said....gen1 and 2 rear struts/springs are interchangable, but Gen3 has a multilink rear end - the strut/springs are totally different and will not work in a Gen1 or Gen2 car. And you can't convert your Gen1 or Gen2 to multilink setup, the car doesn't have the right holes or mounting points.
Phizinza
Post by Phizinza » Wed Jun 30, 2010 7:32 pm
Righto, so the bolt spacing on the rear struts to knuckles is different and gen3 struts won't bolt to gen1 hubs. But the fronts are just a swap and go. Cheers guys.
