Rounded Nut on L series
Posted: Fri Sep 17, 2010 11:00 pm
hey guys,
putting my two inch lift in L series car and have realised that some of the nuts are rounded.
anyone got any ideas as to how to get them off?
cheers,
Angus
Posted: Sat Sep 18, 2010 12:00 am
by GOD
If you can find a six sided or splined socket you might be able to bash it onto the damaged nuts and turn them. Failing that, you can grind a couple of flats onto the nuts and get a good shifter onto them.
Dane.
Posted: Sat Sep 18, 2010 2:36 am
sometimes access allows bigger nut to be welded onto offender
Posted: Sat Sep 18, 2010 10:00 am
by wrxer
use nut splitter. or cut them off with cold chisel. cold chisel is pretty quick.
Posted: Sat Sep 18, 2010 11:27 pm
by RSR 555
First to try would be a 6 sided socket followed by knocking on a smaller socket (cheap one and usually an imperial size), then a pair of vice-grips and lastly a cold chisel :)
