wheel bearing
kevmif
wheel bearing
Post by kevmif » Thu Oct 21, 2010 5:04 pm
So I replaced a wheel bearing on my Brumby a while ago (about a year, hasn't done much driving since)
Got it roadworthied today and apparently the wheel bearing is stuffed.
Only thing I can think of is that the steering knuckle itself is worn as the bearings were new. I even got a mechanic to press them in and grease them for me so I couldn't screw it up.
Thoughts?
Post by Alex » Thu Oct 21, 2010 5:57 pm
make sure the hub nights are super tight
when they do road worthyness they usually just jack it up and give the wheel a jiggle.
loose hub nut will give the same feeling as a rooted bearing.
kevmif
Post by kevmif » Thu Oct 21, 2010 6:01 pm
Thanks. Will pull the split pin out and try to tighten it.
