rear springs, Vort and L sedan and wagon
Posted: Mon Jun 13, 2011 11:33 pm
Thought I'd get this discussion continuing in here
Think I want a pair of rear coils to suit an L Series sedan, RX, GLTA or Vortex in order to correct height wagon springs give at the moment. The wrong ones (wagons) have pink and green paint dabs on one set, another can be identified by colours TBA - don't want them either.
Curious to now what anyone may have as spare to get correct height
Ta
Ad Details
Condition: Very good condition
Comments: 5
Posted By: El_Freddo(0)
12-06-2011 02:29
I'm pretty sure that the coils on the wagons are the same as those on the sedans. The 2wd sedans have a longer strut to make up for the lower mounting position on the swing arm compared to that of the 4wd swing arm.
So if you're running a set of 2wd rear struts in the back of your RX 4wd sedan, you'll have a raised rear end - which is what I think you want to eliminate. In which case I think you'll find that a set of replacement struts for any 4wd L series will sort out the issue.
Posted By: steptoe(0)
wrong....., 12-06-2011 03:54
I have tried a set of 87 Touring wagons in rear of my L Sedan 4WD, and another set that came in a rolling shell sedan likely wagon sourced to replace its air bags.
One set jacked arse up plus 40mm, the other plus 50mm.Still got them marked which ones did what
I also had [past tense] a set of FWD L Sedan rear springs made no difference was hoping to drop arse to FWD specs. Stupidly kept the wagon ones and threw the sedans , aargh !
12-06-2011 13:04
So are you sure you're not after an aftermarket set of lowered springs then?
Sounds like the stock height has been dropped...
12-06-2011 19:29
pretty sure it is not lowered sedan springs I want (just yet ).... the wagon springs at that increased height feels dangerous and looks bloody redickerless.
What I may try is my sedan unts in the back of the Vort and get a better idea of things..ta
Posted By: subius(0)
13-06-2011 07:13
I've got an 85 vortex with a wagon rear end and am currently playing with the spring/strut combo. I bought a brand new set of sedan kyb struts only to discover the spring seat is higher than on the wagon. The sedan springs are a little shorter than the wagon ones though. You can flip the strut tops to drop the rear by about 50mm, need to drill a hole in the wheel arch too. I am thinking this might be a good option for me, otherwise i'm going to have to buy new shocks...again.. Good luck f
Ta
Ad Details
Comments: 5
12-06-2011 02:29
12-06-2011 13:04
12-06-2011 19:29
13-06-2011 07:13
