new struts vs lifter kit
I've read pages and pages in this forum on tyre and rim sizes and I've noticed to get bigger rims and tyres to fit a 1st Gen Liberty Some people suggest changing the struts to Outback ones and some suggest putting in a 2" lifter kit. I also understand that even if they are to big they will rub on the body when turning.
What I want to know is pros and cons of doing one or the other?
or should I do both?
If you do both does that give you a total lift of 4" eg 2" for the lift kit and 2" for the outback struts?
If you put Outback struts on you will get 27.69" tyres on without you will struggle to get 26.92" it will still rub on the bottom of the strut spring cup.
If you go to Forester 15" rims you should get a bit better with the offset.
A 2" lift will give more clearance under the car but you still wont be able to put 26.92" tyres on without rubbing
Putting both struts and springs it will give you 4" all up i have this setup but with hd springs as well i have 215/75/15 (27.69")tyres i do get a bit of rubbing on full lock and with a lot of weight in the car.
Here is a tyre calculator http://www.1010tires.com/TireSizeCalculator.asp to work out tyre diameters
Jan
Jan
I guess I need a bit more clarification on the correct terminology/wording
Is a strut lift just putting those little 2'' block triangular type spacers just above the struts? or would this be called a body lift?
Or is a strut lift just putting on longer struts like the outback ones?
Or is putting longer outback struts on called a suspension lift? or is putting on heavy duty springs a suspention lift?
Do the Outback struts alone give 4" of lift?
As you can see I'm a bit confused.
A strut lift is just putting Outback struts in
A body lift is putting blocks at every part of the car that connects to the suspension and drive train (lift kit) including on top of the struts
Here is a link to an site that has a pic of a lift kit http://www.ultimatesubaru.org/forum/sho ... p?t=114187
Jan
Jan
Ok Thanks for the diagrams and explanations Yarney and Toonga
so a strurt lift can be putting on longer outback struts and can also include putting in the 2" blocks as well on top of the struts.
and a body lift is putting the blocks on top of the struts plus all those other little blocks and bits between the cars body and the drive train, which gives a more even lift around the body.
From the looks of the diagram a 2" strut lift with blocks gives the same amount of lift as putting on just the outback struts.
So I could put on outback struts and HD springs like Yarney(a 4" lift) and fit 27.69" tyres on or I could just do a strut lift with 2" blocks and fit on 26.92" tyres that will still rub.
So going back to my origional post what are the pros and cons of doing
option1 a 2" strut only lift vs option2 outback struts and HDsprings vs option3 a 2" full body lift kit. ??
I imagine option1 would be cheaper and easier to do.
option2 would allow fitting bigger tyres and best ground clearance and ?may damage cv joints
and option 3 would most probably be most expensive and be better for the CV joints.
or a combination? like 1" strut top lift, and HD outback struts, best blend of clearance with the best performance and not the worst option for your CV's, but a midrange price, the labour cost of a full body lift is large, strut top installation is cheap, HD struts will cost a bit, ~1000 bux, but you could almost do a 1" lift at the same time, since the struts would be out, but HD springs offer a large improvment in performance
depends how much you want to invest?
"SUUBMARINE"
20" LED Front Light Bar
Ok I might be able to get some struts and springs out of an outback that has done 240000km's I'm still negotiating a price just below $300
Just wondered am I better off getting new KYB stuts and HD King springs as these have had a few km wear?
Or should I get these second hand struts and then buy new HD springs?
I'm just not sure if the wear and tear would affect there performance much.
Any opinions and suggestions welcome.
300 seem's a decent price. Just did this to a mate's liberty and had problems finding the spring hats, so if you can get the complete set thats a bonus. If you buy new struts, depending on whether you have the air suspension or not you might have to find the strut tops and hats from somewhere. As for the wheels moving forward, ask the guy your getting the struts from for the rear trailing arms as well, as i understand this should fix it.
i just did mine as nic said... few things outback rears wont bolt straight in bit of filing needed in the strut tower not a big issue however... to be honest i'd get lifted purely for the extra height and seems like a really nice ride so far and it's not a massive increase in height so any extra is good... and 200,000km on them probably worth getting new mate no doubt new ones will be better just depending on what your budget allows.. but if you look at it this way you pay 300 for the secondhand + kings = 580.. brand new 880ish... few hundred worth the hassle ?? your decision. and yeh look at roscows liberty build there is a few comments about the rear trailing arm mounts and how they help the forward movement of the rear wheel..
to do list:
to do list:
Me again.
Are these http://www.ebay.com.au/itm/ws/eBayISAPI ... 0437171751
the strut tops that I will need if I put KYB 97 outback struts in a 92 liberty with HD king springs?
Do I need them for just the rear or will I need them for the front as well?
you'll need 4 strut tops.. if your current suspension has the non tapered springs (cone shaped) and just the straight springs you'll be able to use the 4 strut tops from your liberty ones.. otherwise you could use those strut tops and drill new holes or file the current ones out a little... but that price seems excess call around some wreckers i picked some second hand ones up for 80...
thats my car there with the struts and springs in... and not a very good picture
thats it next to a mates l-series which has a 3" lift in it gives you a better indication of height and all of the driveline etc actually has more clearance then his car.
to do list:
to do list:
Cool pics Woody thanks
The second hand ones that were for sale have gone
Well I just did some ringing around for prices on new outback struts.
Coventry's don't have any and would have to get them shipped from over east and he said the frieght on top would make them very expensive he could not give me a price.
Repco only had fronts at $211 each no rears so no price.
Malz had no idea and will call me back still waiting.
Supercheap RF $215 LF $275 Rears $335 each...... what tha!
Subaru parts wangara wanted the vin number no vin = no price
Hmm After reading one of Venoms posts http://ausubaru.com/forum/showthread.php?t=18191 looks like I might have to try USA
i think you'll find shipping on struts alot more expensive then getting them here... i paid 165 a strut at supercheap including postage.. ask around your friends see if they know of anyone who works there staff discount is quite good.
to do list:
to do list:
