KYB Shocks
KYB Shocks
Does anyone know the part number for the adjustable KYB L series shocks please?
'86 Brumby - Dual Port Heads, 5 Speed Dual Range, Custom Cam, Tuned Weber, Tuned Suspension, 2" Body Lift Kit, LSD, 14" rims, 2.25" Exhaust, Snorkel, Dual Batteries, DVD Player, UHF, VHF, etc. Offically now part of the 350, 000 km Club! And still pulling like a freight train.
"Claudia"
"Claudia"
From what I've found, KYB only made the adjustable ones for Subaru and they were (not available anymore) only available from Subaru Spare Parts.
I've only seen them on 85 and 86 models too. I'm sure others have fitted them to later models but never from factory. Of course the MY series had them on the front too but this thread is talking about L.Series ones.steptoe wrote:Really only thought they were 85,86 L wagons that got them originally
To answer the questions yes rears... My bad. King springs are able to make custom height springs, rates, etc. However bear in mind that standard height king springs will be stiffer therefore make the car sit higher then normal height.
"Claudia"
"Claudia"
For the rear you can't got past the honda front end springs from the early nineties - I've got a set in the back of Ruby Scoo and wished I had have done it much earlier!Mitchhsj wrote:can you get higher springs like from king springs or any similar company for l series, that will go in to stock towers??.. thanks
About the factory adjustable rear struts for the L series - I thought they were pre '87 too.
Hey El Freddo. I got the Honda springs (std) with the KYB strut (+3" lift) and i found out the hard way that if you dont extend your bump stops they snap the spring seat off. I quickly welded some extensions onto the bump stop plate measuring about 10cm high cos i was going on a trip lol.. TOO HIGH! I ran on bump stops the whole way. Perfect ride height when fully loaded tho Anyway, what did you do with yours?
Any chance one or both you fellas could post some pics or start a thread about this?
The rear spring mod was something i was about to have a crack at, but now i am a little dubious after reading the last 2 posts in this thread.
My head is a little hazy right now but i take it the bump stops is the rubber cone on the shock absorber rod?
Or is the bump stop the rubber mount located between the body and the read suspension arm?
Sorry for partial thread hijack.
EDIT: scrolled down a bit and found showthread.php?t=22646
Now have a slightly better idea, though some pics wouldn't go astray
Already done here. It's buried in the middle of the thread but that's the one that counts!M0rpH wrote:Any chance one or both you fellas could post some pics or start a thread about this?
It's up to you. I love it and have changed my driving style. My spring seat failure was due to a dodgy shock not doing what it should have been doing, this allowed more force to act on the spring seat that eventually knocked it offM0rpH wrote:The rear spring mod was something i was about to have a crack at, but now i am a little dubious after reading the last 2 posts in this thread.
There are both, but wagonman is talking about the rubber mount located between the body and the swing arm.M0rpH wrote:My head is a little hazy right now but i take it the bump stops is the rubber cone on the shock absorber rod?
Happy reading!
