RS Sedan struts into GX Wagon?
scott
Post by scott » Sat Nov 24, 2012 11:05 am
Can anyone confirm that Gen1 Liberty RS sedan struts will fit straight into a Gen 1 Liberty GX wagon?
Looking to ditch the dodgy air suspension.
Have found these RS complete spring/struts and only have a few days to score them.
Anyone's help would be great!:)
Post by Gannon » Sat Nov 24, 2012 11:13 am
Yeah should bolt straight in
Post by RSR 555 » Sat Nov 24, 2012 3:04 pm
Yep. Seeing that your car has air struts, then it will be an AWD model then it will be a straight swap. If it was 2WD then only the front would have fitted.
Oh.. Hi and Welcome to AUSubaru Scott
vincentvega
Post by vincentvega » Sun Nov 25, 2012 9:35 am
you might find it sits a bit low in the rear with sedan gear. That can be solved wiht a set of king springs later if you need to.
