lift blocks for Brumby
Dean.nabbe
Post by Dean.nabbe » Mon Jun 23, 2014 7:16 pm
does anyone know where i can get these from or where i can find design specs to make my own?
henpecked
brumby lift kits
Post by henpecked » Mon Jun 23, 2014 8:36 pm
these two will both be able to sell you a brand new lift kit , and almost certainly provide you with the correct steering extension for your situation ( power steering or no power steering etc). Subawreck may have some secondhand sets available as well.
[url=http://www.*********performance.com/]http://www.*********performance.com/[/url]
http://www.subareck.com.au/
then there are adds like this
http://www.gumtree.com.au/s-ad/cooyar/o ... 1048333600
where the seller does not know that L series and Brumbys are different kits.
the two lift kits that were linked on the other thread you posted in have now been sold.
Dean.nabbe
Post by Dean.nabbe » Mon Jun 23, 2014 9:00 pm
thanks...
i waiting to sell my boat before i can start some serious work on the old girl... is there anyone that still makes them or has them on a regular basis... atm i'm trying to research availability so once the funds arrive i can start buying it all..
i'm also gonna build my own winch bar to fit a 6000lb winch(recommended size for vehicle weight) i'll post pics when i get it all finished..
Post by TOONGA » Mon Jun 23, 2014 9:33 pm
this page might help but it is 6 inch
http://www.angelfire.com/on4/bushy5550/lift.html
With the offset on the strut spacer/blocks you need 6-7mm for every 25mm, this is very important otherwise your camber will kill tyres.
Good luck
Dean.nabbe
Post by Dean.nabbe » Mon Jun 23, 2014 9:59 pm
http://www.k-mac.com.au/pages/newprods/ ... subaru.htm
this might be handy for anyone looking to go higher... pretty costly exersise by the looks of it though..
Dean.nabbe
Post by Dean.nabbe » Wed Jul 02, 2014 9:51 pm
[quote="TOONGA"]
With the offset on the engine blocks you need 6-7mm for every 25mm, this is very important otherwise your camber will kill tyres.
[quote]
do you mean the strut spacers? or the blocks under the engine cross member?
Dean.nabbe
Post by Dean.nabbe » Wed Jul 02, 2014 9:52 pm
TOONGA wrote: With the offset on the engine blocks you need 6-7mm for every 25mm, this is very important otherwise your camber will kill tyres.
do you mean the strut spacer or the block under the engine cross member?
Post by TOONGA » Wed Jul 02, 2014 10:00 pm
Dean.nabbe wrote:do you mean the strut spacer or the block under the engine cross member?
Sorry That was meant to read strut blocks/spacers not engine blocks.
Im not sure what happened there.
Im going to edit that post for future reference.
Dean.nabbe
Post by Dean.nabbe » Wed Jul 02, 2014 11:12 pm
sweet... i knew about the strut offset, but you kinda threw me.. lol
