nncoolg
Post
by nncoolg » Mon Jun 08, 2015 9:48 am
I want to do some measuring, but I don't have a spare, does anyone have one lying around?
Actually the bushes are the same part from 2wd or 4wd so that may make it easier...
reason for inquiry : I want to get measurements for "part 2" to see if we can find a poly replacement and a look at "part 3" to see what we're dealing with...
# Vortex Main Dash Surround / Bezel
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
4speed auto digital dash,
# EA82 AWD 4EAT,
If you have them please PM me
Post
by steptoe » Mon Jun 08, 2015 10:23 am
I'll have a look but think I chucked my L Series stuff as you must have also with last wreck!
What measures do you want ?
nncoolg
Post
by nncoolg » Mon Jun 08, 2015 6:12 pm
ID, OD & Length of 'part 2'
picture of 'part 3'
Update : I just had another look at the parts catalog and all crossmembers are the same 2wd and 4wd so that may help find one...
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
FujiFan
Post
by FujiFan » Mon Jun 08, 2015 10:43 pm
I have these at home. Will measure and pic tomorrow. If there is a poly replacement for part #2 - I am all ears, er eyes.
J.
nncoolg
Post
by nncoolg » Mon Jun 08, 2015 10:52 pm
thanks, sounds good.
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
FujiFan
Post
by FujiFan » Tue Jun 09, 2015 6:26 pm
Neville here are my findings.
Part#2
ID = 14.5mm
OD = 57mm
H = 60mm
L = 78 The inner steel tube in this bushing extends 9mm either side beyond the 'H' measurement. (similar to rear diff xmember bushings but bigger)
I dont know how to get pics from my S5 into my PC so I couldnt upload pic I took of part#2.
This pic of part#3 is borrowed from else where.
J.
nncoolg
Post
by nncoolg » Tue Jun 09, 2015 8:00 pm
Fujifan you can attach photos by clicking 'manage attachments' in the 'additional options' box below the reply box.
Or you can install the photobucket app on your phone
Or PM me and Ill send you my email and Ill put them up
thanks for the measurements
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
nncoolg
Post
by nncoolg » Sat Jun 13, 2015 12:35 pm
any chance of those photos Fujifan?
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
FujiFan
Post
by FujiFan » Sat Jun 13, 2015 5:22 pm
Been working long hours. Will do when I get a chance.
nncoolg
Post
by nncoolg » Sat Jun 13, 2015 5:52 pm
Sweet, I found a bush from nolathane that may suit the application...
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
FujiFan
Post
by FujiFan » Sat Jun 13, 2015 5:56 pm
FujiFan
Post
by FujiFan » Sat Jun 13, 2015 5:58 pm
nncoolg
Post
by nncoolg » Sat Jun 13, 2015 6:07 pm
I wonder does someone have an old crossmember that can press one of these bad boys out so we can get a proper OD measurement?
Also, keen to see other sides of the 'flat' bush to see how it looks...
when you get time
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
nncoolg
Post
by nncoolg » Sat Jun 13, 2015 8:53 pm
This is the one that I reckon may go close based on your preliminary measurements (
compared at the bottom)...
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
FujiFan
Post
by FujiFan » Sat Jun 13, 2015 11:00 pm
Your certainly keen on this one arent you. I like the idea of replaceing every bush on the old L, but why these ones. They will be a mongrel to wrestle with once you muster the courage to remove from vehicle.
I suppose I could remove the ones outta the one I have. But I expect it to be an epic job.
J.
Post
by Silverbullet » Sat Jun 13, 2015 11:27 pm
FujiFan wrote:Your certainly keen on this one arent you. I like the idea of replaceing every bush on the old L, but why these ones. They will be a mongrel to wrestle with once you muster the courage to remove from vehicle.
J.
They look a bit like the moustache bar/rear diff pinion mounting bush on a Brumby, roughly same size. In which case you really need a press and specially made punch + die to get them out "easily". Otherwise you're cutting/burning the rubber insides out then hacksaw and hammer/chisel out the shell...which is not a fun job
FujiFan
Post
by FujiFan » Sun Jun 14, 2015 12:25 am
I tend to agree with you there SB. And I have stripped down a couple of rear diff xmembers and the matching pinion mounts using all 12tons of a workshop presses force. Talk about busting a poop poov valve as Carl Barron would put it!
nncoolg
Post
by nncoolg » Sun Jun 14, 2015 10:41 am
Why these bushings? Well I figure there's no point in stiffening up suspension components if what they're mounted to is all mushy.
About as much point as a 'cat back' exhaust when the pipes in front of it are smaller. Start at the top and work down or don't bother.
Actually I'm not sure why the crossmember is rubber mounted when all the parts branching of it are insulated as well. The front crossmember is bolted straight to the body...
ANY COLOUR,
# Vortex Radio,
# RHD Vortex
# EA82 AWD 4EAT,
FujiFan
Post
by FujiFan » Sun Jun 14, 2015 12:19 pm
That makes sense. I like your thinking.
Removing those bushings is a bit of an excuse for me to finally get around to putting speedholes + blasting and powder coating that rear crossmember
No promises. I will see how I go for time this week.
FujiFan
Post
by FujiFan » Mon Jun 15, 2015 12:33 pm
More specific pics of 'Part #3'
Doubt there is an aftermarket for these particular mounts. My thought would be to fill these with urethane in order to firm them up.
J.
