MY thread size
MY thread size
Anyone know the thread size/form and TPI for the front drive shaft for an MY/Brumby.
I have a spare front drive shaft I want to rebuild but the drive shaft thread is damaged on the end where I suspect someone has hit it with a hammer to get it out of the bearing assembly.
- Silverbullet
Don't know the thread size myself, but I'm willing to bet it's a metric fine thread. Is yours mushroomed over on the end? Depending on how bad it is you can put a chamfer around the end with a grinder or some such until the deformed bit is gone. Can't take off too much though.
Thanks for the info.Silverbullet wrote:Don't know the thread size myself, but I'm willing to bet it's a metric fine thread. Is yours mushroomed over on the end? Depending on how bad it is you can put a chamfer around the end with a grinder or some such until the deformed bit is gone. Can't take off too much though.
Yes, it would definitely be metric, I may have to get off my lazy butt, pull out the metric thread gauge, work it out and grab the metric thread file.
Only the first 1 or 2 threads are damaged, not too bad in all, just enough so the nut wont start and if I try I will only bind the nut and shaft threads together stuffing things more. Think I will try to reform the threads with the thread file first and then go to chamfering as a last resort
- Bantum
Thread cleaner ...
You'll want a M24 x 1.5 Die : ( Right handed thread )
Edit : Lefty - Loosens & Righty - Tightens
Clean up with one of these :
( another handy tool to add to the workshop )
Cheers, Bantum ...
Cheers, Bantum ...
- Silverbullet
