L series strut top bearing replacement?
Has anyone had prior success replacing the 6203 bearing in the strut top? Seems to be crimped-in...
# EA82 AWD 4EAT,
If you have them please PM me
# EA82 AWD 4EAT,
Thats an interesting idea Fujifan, I wonder are there any more after market options?
Were the Kmac ones a direct fit, or did you have to fudge the 3 holes?
Steptoe, they are pressed in from the bottom, then what looks like a crimped over cap
# EA82 AWD 4EAT,
# EA82 AWD 4EAT,
They were a direct fit. No bodgyness at all was needed. couldn't be easier. Plus you get about 10mm lift on the front because of the design versus the OEM strut tops.Were the Kmac ones a direct fit, or did you have to fudge the 3 holes?
Just not the cheapest option at $480 a pr. But they are nicely made and a fair amount of adjustment is available.
- Silverbullet
Wish I could go this route, but I'm not confident of their listing for L series, MV/Brumby and MY being the same part Also probably not legal here in SAFujiFan wrote:They were a direct fit. No bodgyness at all was needed. couldn't be easier. Plus you get about 10mm lift on the front because of the design versus the OEM strut tops.
- Silverbullet
Oops I should have said they would need to be signed off by a "chartered professional engineer" after you've filled out a "Application to modify a motor vehicle" form with the relevant bla bla bla only for a cop to pull you over, take one look at them and defect your vehicle on the spot ignoring all your legal paperwork. Yes it happensEl_Freddo wrote:Why wouldn't they be legal?
Like most things
