Front Suspension Mod's Dial Up Warning
Posted: Sat Jun 09, 2007 7:05 pm
by Matt
I just brought some 3" lifted front struts off Steve at Rising Sun. They are awesome and i thought i would throw up some before and after pictures of them. I removed the top lift block and original strut (2 body lift block and king springs on Subaru shocks) and fitted them up. This gave me an increase of nearly 50mm. And about 75mm more suspension travel.
Before
Strut Difference
Strut Difference
New Strut Fitted
Posted: Sat Jun 09, 2007 7:39 pm
by Subafury
feck yeh imagine with the lift block too :D
Posted: Sat Jun 09, 2007 10:20 pm
by SuBaRiNo
Looks great... VERY interested in the same set up... do you mind sharing the costs involved or is there another post about these.
I assume this new set up has the correct offset built into them depending on the size of your lift kit or your camber would be effected... how is the camber now?
Dave
Posted: Sat Jun 09, 2007 10:59 pm
by 90brumby
yes also interested in this set up
Posted: Sun Jun 10, 2007 1:10 pm
by Matt
Subi: with the lift block still there i would estimate the CV's to last about 100km, considering the angle they are on now. Also you can still wind them up as they still have the original strut base plate. Also note i am running L series shafts, etc, so my angle would be less then if you were using standard.
SuBaRiNo: It has cost me about $580 in total for the shocks, springs, top hat and freight. The camber would be effected, however i am running L series control arms and Kmac camber adjuster. So i am close to 0 degress camber on the front and about to be the same on the back.
If i remember i will take some photos of the camber later this afternoon. Got to go and finish the rear suspension mod's.......
If a couple of you guys are serious about doing it i could do a conversion kit?
Posted: Sun Jun 10, 2007 6:58 pm
by 90brumby
dependin on the price of it yer i will want 1
Posted: Sun Jun 10, 2007 7:07 pm
by Matt
Sorry about the dodgy picture but it gives you an idea of the camber and control arm angle. Remembering i have L series control arms and camber kit
Posted: Fri Jun 15, 2007 4:33 pm
by mroberts
If anyone's interested, I have a set of the nolathane strut tops I'd be willign to part with ...
Posted: Fri Jun 15, 2007 4:40 pm
by Matt
How much for them?
Posted: Fri Jun 15, 2007 8:22 pm
by SuBaRiNo
How much and where did you get them... i never knew they made them to suite the MY struts. Pics??
I ended up with genuine Subaru ones but im sure Nuls would be better.... maybe.
Dave
Posted: Mon Jun 18, 2007 10:11 am
by mroberts
They are from the Blackbox group buy. Not sure if they'll fit an MY. I'll see what I can find out.
I'd be willing to part with them for $330 - what I paid fof them through the group buy. I think now they are $380.
Are MY strut tops 2 or three bolt ? Mine are three.
Posted: Mon Jun 18, 2007 1:16 pm
by 90brumby
MY strut tops are 2 bolt 3 bolts are L series and other stuff
