Adaptors for brumby rear suspension to fit needle top shocks
Any idea where I can get these from ? They're used to fit pump-up shocks to the back of a brumby/MY. I know a few of the guys in WA have them. I used to have a set but they went missing.
shock Mount
So is the new improved version Johnny, or the bendable version if you drive to fast on sand dunes with 5 blokes in the back? LOL What is the recomended shock manufacturer and which model is the one to go for?
same difference for those.
or you can use the l series top bracket;
get a bit of flat bar, drill 2 holes the width of the L top Mount
put one bolt through on the MY
mark where the other hole is on the MY, and drill it
bolt the flat bar to the car and L top mount to the flat bar, using one of the bolts straight through both
Got a welder? Not hard to make.
Yeah second that not hard at all to make, when i get home i will post some pics of mine.
"Claudia"
"Claudia"
