Baintech Dual battery kit
Posted: Tue Sep 23, 2008 9:00 pm
by Outback bloke
I bought one of these the other day and fitted it to my ute. It is nothing flash or gimmicky but it seems to work very well.
The kit comes with every thing you need to connect it all up including easy to follow instructions. Very much like other brands I suppose and time will tell how it goes.
They are a bit cheaper than other brands around.
http://www.baintech.com.au
Posted: Wed Sep 24, 2008 4:16 pm
by INEEDABEER
How much were they Brett,Im in the market for one.Where did you get it from?
Posted: Wed Sep 24, 2008 5:41 pm
by Outback bloke
Gav, I got it at battery world here in Caboolture. He is a mate of mine and I got a good price on it. $152 mates rates. RRP is $180
I could get a better price if we wanted to do a group order on them. Might be an idea. See if we can get 5 or 10 people that want them.
Posted: Wed Sep 24, 2008 5:55 pm
by MOONEY
i would be very interested in one if you wanted to do a group buy. where did u put the kit
Posted: Wed Sep 24, 2008 6:16 pm
by INEEDABEER
I'm up for it!
Posted: Wed Sep 24, 2008 6:38 pm
by Outback bloke
MOONEY wrote:where did u put the kit
Under the bonnet just near the battery.
Posted: Wed Sep 24, 2008 6:54 pm
by stamp_licker
I'll take one if the group buy gets off the ground
Outback bloke wrote:Gav, I got it at battery world here in Caboolture. He is a mate of mine and I got a good price on it. $152 mates rates.
I thought he retired after you solar powered the ill fated trek.
Posted: Thu Sep 25, 2008 7:44 pm
by INEEDABEER
Baintech said battery world up here stocks them and are $169.00 RRP I'd be interested to see what we could get them for.
Posted: Thu Sep 25, 2008 8:32 pm
by Outback bloke
Wonder is it is the same kit? I will ask him what deal he can get for us if we order a few.
Posted: Fri Sep 26, 2008 6:33 am
by INEEDABEER
It is the same one,i sent an email to Baintech through there website.
Posted: Sun Sep 28, 2008 7:58 am
by the gumbi brumby
im keen ive been planin this mod for a while
Posted: Mon Nov 03, 2008 2:55 pm
by chubby37
The BAINTECH Dual Battery Control Kit - $179.00 RRP (Data Sheet Attached).
Available in both: -
12volt 100amp – Part No. BTVCR12VDIY
24volt 70amp - Part No. BTVCR24VDIY
The kit includes: - Relay, cables, cable ties, lugs, heat shrink & connector.
The BAINTECH Voltage Control Relay - $99.00 RRP (Data Sheet Attached).
12volt 100amp – Part No. BTVCR12/100
24volt 70amp - Part No. BTVCR24/70
Posted: Tue Nov 04, 2008 8:30 am
by tex
Excuse my ignorance but I cant see $80 worth of extra goods in the dual battery kit, What am I missing As I would be interested in 2! Also I couldnt get access to the data sheets!
Posted: Thu Dec 11, 2008 12:38 am
by whatcharterboat
Hey This isn't intended to be a hijak but I've been installing Dual Battery Systems for over 20 years and this is by far the best thing I've seen. Only been on the market for a few months. They are imported by BLA. (see bla. com for a distributer)
http://www.bepmarine.com/High-Current-R ... -1472.html
It is dual sensing, so if you have another charge source set up to your axillary battery such as a solar panel it can also top up your start battery so it works both ways.It also forces the parallel > a lot of VSRs don't but this is really only important if your aux battery is really big. But what makes this unit better (IMO) is that it can also handle vehicle starting current so you can remotely push a button on the dash and a motor in the switch turns it "on" and parallels your batteries effectively giving you a "jumpstart" if your start battery is low. Read the specs.
Also IMO they were cheap for what you get. BEP do heaps of different dual battery stuff but this is my pick. Piece of cake to install too.
Good to catch up on Ausubaru. Been away for awhile. Thanks
John
http://www.atwarrior.com.au/
Posted: Thu Dec 11, 2008 8:21 am
by vincentvega
the BEP stuff is good gear, as is the Redarc. Both can handle starting currents, and have override buttons, but you need to wire / fuse the secondary battery heavy enough to allow this.
