How to change front speakers in a gen 1 lib
hey all, last night i tryed to change the front speakers in my bros lib and I came a cross trouble. do you need to pull the whole door panel off, or does it unclip?
Cheers Ethan
Cheers Ethan
Current Ride - 85 Touring wagon, All electrics, KYB long travel struts, Power Steer, Mags (swapping for sunnies).
- vincentvega
Its a '92 lib. Havent got the new speakers in yet, Ethan (ol Kid) My brother pulled it apart and decided to put the speakers in the back as they were 6 and a half inch splits, Wouldnt fit in the front.
when i do get the front ones in ill take some pics and put them up.
get spacers. Nearly every car needs them.ol kid wrote:Yeh i did sit the speakers in and the magnet hit on the inside of the window. If you put the window up it would fit in but in turn your window wouldnt go right down. Cheers Ethan
I did my sister's gen1 a while ago and they needed about 2cm worth of spacing. But it depends on what speakers your running.
most importantly make sure you get an airtight fit inbetween the door and the speaker. You will loose alot of bass otherwise.
flat ones will get you out of trouble. You still want abit of midrange though. Its all about SQ, not pure ear-bleeding ground shaking bass!!(although im abit partial to this myself:))
cheers
cheers
